Old 01-19-2011, 10:01 AM
Halfbraz Halfbraz is offline
Iinstalling a kill switch?
HI,I would like to install a Kill Switch in my 95 Ford F-150. Should I add the kill switch to the fuel pump or the ignition switch? Why do people choose one over the other? What is the minimal wire size I can use and add the switch to the positive side only? What type switch is recommended?Tom
Old 01-19-2011, 06:02 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Iinstalling a kill switch?
I would kill the fuel. If you kill the spark, the fuel could still be pumping for a little and may cause problems. A spark in an empty cylinder will cause no harm. I would use the same size wire as is going to the pump.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-20-2011, 04:47 AM
PAINTER78 PAINTER78 is offline
Any ideas on how to wire in a fake kill switch to siren that can't be turned off for a set amount of time?
What do you know about a KILL SWITCH?!?!?! natcc99 Car Audio 17 06-05-2012 06:21 AM
Do-It-Yourself: The Guide to Fuel Pump Kill Switch and Starter Kill Relay Circuit Di kris Interior | Audio | Security 0 05-04-2005 01:24 AM
kill.switch vectorclub Other Games 5 07-19-2003 10:11 AM
HELP:Reset or Kill Switch on 2000 323I???? psycorav 3 Series 0 07-11-2002 02:02 PM
secret ignition kill-switch relay Brian P Audio/Security 27 04-09-2002 03:44 AM
Tags
kill , switch
