Old 01-17-2011, 07:41 PM
Hola Hola is offline
LeSabre 1993 - hard to start
Our Buick always hesitates to start. It started some months ago and although it alwasy starts it is anoying because sometimes it feesl like it wil not start, but ultimately it does starts. Any help would be appreciated. Thanks.
Old 01-17-2011, 09:41 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: LeSabre 1993 - hard to start
What's the last time plugs,wires & fuel filter were changed? What is the fuel pressure when you turn the ignition ON? Hard to troubleshoot this without without some basic diagnostics first.
Old 01-20-2011, 09:40 AM
jcc3inc jcc3inc is offline
Sir,
I believe that the fuel pump should come on for about 2 seconds when you first turn on the switch to start. Usually you can hear it if you're in a quiet place. Maybe you should check on that. This supplies fuel pressure to start the engine.
Regards,
JCC
Old 01-21-2011, 12:53 PM
Thanks for all the responses. I changed the spark plugs and wires 12,000 miles ago, so, it should not be these items. By the way, this car has alwasy been quick to start it always surpised me how easy and smoth the starting has alwasy been, so this problem bothers me and don't know how to look for it and do somenthing about it.
Is there a way to test the fuel pump before getting a new one?
Again, thank you for help.
Old 01-21-2011, 10:46 PM
HotZ28's Avatar
AF Moderator Elite
Originally Posted by Hola View Post
Is there a way to test the fuel pump before getting a new one? Again, thank you for help.
Yes, test fuel pressure as suggested.
Old 02-04-2011, 11:06 AM
Well, the mechanic did check fuel pump presure and said it was fine and then went ahead and replaced the started, but the problem still continues, so, obviously it was none of those two items. Don't know what else to do now.
Thanks for the help.
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
Buick LeSabre 1993 hard to go Hola LeSabre 8 09-13-2010 09:31 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
