Old 01-17-2011, 03:46 PM
lwheel lwheel is offline
Question 1994 Multi elec. problems
I have a 1994 cherokee sport 2wd 4.0 Starting have a problem with the electrical one day, radio, heater, blinkers, lighter and wipers quit working while driving, about 5 minutes later they started working again, then later the same problem once again. This went on for about a week, and then they just stopped all together. Everything else worked with no problem, then when I went to the store I parked it, went in side and when I came back out the jeep would not start at all, no nothing, lights would work but nothing when I tried to turn over the engine, so I put the key in the on position crawled underneath jumped the started with a screwdriver to get it started, drove it home turned it off, tried it again but it would not start unless I jumped the starter again. The motor will start once I jump the starter but the all the other problems are still there, I checked all the fuses and there all good, could this be a relay issue or something? Thanks
Old 01-17-2011, 04:28 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 1994 Multi elec. problems
Sounds like a ignition switch failure. It's the central nerve of the electrical system.
1994 Corsica Won't Start Ragarianok Corsica 0 05-09-2010 04:53 PM
Odometer and Fuel Guage Elec. problems smcelhe C/K 10 03-04-2004 12:02 PM
97' - Mother of all Elec. Problems IceFog14 C/K 1 03-02-2004 08:02 PM
Front blinkers/elec problem drjoe 3 Series 4 12-18-2003 10:25 PM
98' Monte Z34 elec problems HELP!! 1Racer-x Monte Carlo 3 10-28-2003 03:38 PM
