Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 01-15-2011, 11:09 AM
chadmpiatt chadmpiatt is offline
02 Sportage 4wd
02 Kia Sportage 4wd jumps into 4wd while driving and make a popping and grinding noise, i don't know why. Can anyone help me?
Old 01-16-2011, 07:35 AM
LMP's Avatar
LMP LMP is offline
Re: 02 Sportage 4wd
Common...this means that the vacuum solenoid valve is leaking vacuum into the hubs. Just for testing, disconnect the vacuum tube to the hubs at the solenoid and see what happens.
www.avigex.ca/kia/vacsol.jpg
INdeed, applying vacuum hubs while the t-case is still in 2WD means the hubs will force the front half-shafts, differential and front driving shaft to catch up with wheel speed.....which might already have damaged the hubs...so stop this at once.
YOU can run the vacuum solenoid electrically on and off and run wd-40 through the ports with engine running or using compressed air to try yo dislodge dirt in hope it will become tight again. I did it once but eventually, had to change the original hubs to WARN auto-mechanical.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
2000 Kia Sportage died on fwy. Will Turn over but not start...HELP over_kia Sportage 3 10-16-2010 02:11 AM
00 KiA Sportage 4wd Locking Up on Turns HPYUNBDAY Sportage 3 08-28-2010 06:41 AM
2001 Kia Sportage driveshaft problems KPyle Sportage 3 02-19-2010 06:56 AM
97 Sportage 4wd and #2 misfire problems RickCJ7 Sportage 3 01-08-2009 04:14 AM
2001 Sportage 4wd traceme Sportage 1 01-07-2005 03:39 PM
