Old 01-15-2011, 10:14 AM
dedrums dedrums is offline
Angry 95 jimmy heat problem HELP
have a 95 jimmy temp runs fine on the highway i put the heat on and the air is warm when i drive in the city and stop at a light the gauge starts rising passed 210 and the air turns cold(coming out of the vent)when i drive again the gauge drops and the air turns warm again.cloged system i own the car for 4 yrs now never flushed it.someone please help
Old 01-15-2011, 03:58 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 95 jimmy heat problem HELP
This sounds like a partilly clogged cooling system. Take a look first and make sure the system is full and is not low on coolant from a leak etc. Take the cap off the rad and take a look in there to see if its low. Also, take a look in the rad and see what it looks like. Does it have a lot of build-up/rust deposits? If the coolant hasn't been changed for at least 4 years, it would be wise to do a complete and through flush and refill, especially if your using dexcool.
1999 Jimmy Heat Problems upacreek Jimmy 1 06-13-2011 06:26 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
98 jimmy heating problems armallard Problem Diagnosis 7 10-11-2008 09:08 AM
2001 GMC Jimmy SLS Problems. Help! Jackfrost0 Jimmy 4 05-24-2007 11:20 PM
jimmy heat problems jlneis Problem Diagnosis 4 03-03-2007 10:03 AM
