Old 01-12-2011, 08:53 PM
Off_Timing Off_Timing is offline
Changing Stereo?
Hi Guys,
I did a search for Windstar stereo and almost all I came up with is related to the blend door actuator.
Here's the deal. My wife has a 2000 Windstar (3.8L V6) and the stereo has the cassette player. I have a chance to get a CD player stereo for next to nothing. My question is....there's no issue with swapping stereo head units between Windstars, right?
What I mean is the stereo isn't coded to a particular vehicle so a stereo from another Windstar should work in my wife's Windstar???
Thanks.
Old 01-13-2011, 12:30 AM
mark_gober mark_gober is offline
Re: Changing Stereo?
Originally Posted by Off_Timing View Post
Hi Guys,
Thanks.
Not that I know of. The stereo doesn't have any special computerized functions. The connectors might be different, but I doubt it. You can just look at the connector on the radio and be able to tell the difference.
Mark
Old 01-13-2011, 07:10 AM
hocky88 hocky88 is offline
You will know the answer in a short time! I just pulled mine to replace the blend door and I made sure to buy the "U" shaped tools for about $5 to pull the radio. It comes right out and you can look at the connections. I ahve nver read where different models use different amps, etc. so I would ge the radio and go for it. Again, it will take you less than a half hour to know whether it will work or not. Good luck.
Old 01-13-2011, 09:57 AM
Thanks Guys.
That's what I thought....I figured I'd check anyways. I don't have a heated garage and it's pretty cold out this time of year. I didn't want to fiddle with the radio on 2 different vans just to find out I couldn't swap them. Good thing I kept my homemade radio removal tool that I used last summer when I replaced that all too famous blend door motor.
'99 Neon Highline Stereo Problem BarneyMobile 1st Gen 95-99 4 02-24-2010 07:50 AM
stereo question firefoxx04 Car Audio 7 12-21-2009 09:39 PM
Connecting remote column to stereo marianop Renault 19 1 04-16-2009 03:47 PM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
changing stereo fredsuthers '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 01-13-2004 10:58 AM
