Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-12-2011, 06:35 AM
kenny727 kenny727 is offline
Fuse keeps blowing
I have a 1993 Lincoln Town Car. My number 17 fuse keeps blowing. I looked in the owners manual and it says the fuse is used for the following parts:
Anti-theft, ATC, courtesy lamps, keyless entry, power mirrors, and memory seats.
As of right now whenever I hold my "Unlock" button on any of the doors it turns on my headlights, so I figured it must me a wire touching somewhere. I just dont know where to even start, and taking it to a shop is not an option to me. Any advice helps. Thanks.
Old 01-12-2011, 01:45 PM
danielsatur danielsatur is offline
Re: Fuse keeps blowing
A fuse is to protect a circuit from damage.
There's a short in one of your circuits, causing the blown fuse.
1) Start by disconnected the electrical connector to the electric memory seats, and power mirrors.
2) Try another fuse 17.
Does it blow?
Old 01-12-2011, 04:23 PM
Yeah I smelled burning right when it happend, so I know it's a wire problem. I just need to findout where to look. Since my lock button turns my headlights on I know it's wherever those two wires would be near eachother. Any advice on where I can look for that?
Where would I find the electrical connector for the memory seats?
Old 01-12-2011, 04:49 PM
I was trying to figure out, what would be the most wear + tear in florida.
I would rule out the mirrors, because there's no ice.
1) Try to isolate and disconnect the drivers side electric seat motor, it's under the seat.
2) Do a visual inspection on the electrical buss line from the drivers side door to the body of car.
Old 01-12-2011, 09:57 PM
Im kind of confused how unplugging my drivers side door would help when its my lights/locks that are messed up. Can you explain?
Old 01-13-2011, 02:35 PM
You got four circuits connected to fuse #17, you are trying to isolate one of them out of the loop.
1) If you disconnect the electric drivers seat from the loop, and fuse 17 doesn't blow, Yes
Focus on the drivers door, because of wear + tear!
2) Do you see any cut's, wear, or tear on the electrical buss line from the opening & closing of drivers door?
3) If not, take the drivers door cover off, and disconnect the control module on the inner door.
Old 01-18-2011, 12:13 PM
I disconnected the seat + Headlights and it still blew the fuse. Do you know where the alarm is at so I can try that?
Old 01-18-2011, 01:50 PM
4) Try another fuse #17.
Old 01-28-2011, 02:13 PM
mitchell12 mitchell12 is offline
Hell put a new fuse in and turn the key on. If your fuse doesn't blow, its the outlet. how do you remove that trim panel? ive looked at it and cant figure out how it comes off.
Cheap Lexus Accessories
Old 02-25-2011, 01:57 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Disconnect the cigar lighter and the auxiliary output under the right side of the dashboard, then see if the problem persists.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
PLZ help 94 grand am ignition fuse keeps blowin! thewizard67 Grand AM 7 05-03-2014 07:46 AM
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
Fuse keeps blowing-90 trofeo-body fuse 2 (20) CHPEARL General Discussion 2 10-11-2004 11:28 PM
Tail light fuse keeps blowing help!!! desikoncepts '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 12-30-2002 09:18 PM
Car Stereo FUSE keeps blowing . chris26969 Car Audio 6 12-10-2002 09:49 PM
