Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 01-10-2011, 10:45 PM
prkuykendall prkuykendall is offline
Angry 2000 Oldsmobile Bravada fuel or ignit switch probs or what?
2000 Olds Bravada How to check if fuel pump is good without pulling tank? already replaced fuel pump relay & fuel filter. after many attemps to start the pump will kick on. but fails at next try. need help on this without spending lots of cash troubleshooting...got coder & it says PASS no codes to detect..
fuel pump does not come on...till after many attempts to start or i go off & on with the key & it has came on 1 time like that...but next start attemp pump does not come on.
Old 01-11-2011, 06:52 PM
old_master's Avatar
Advisor/Moderator
Re: 2000 Oldsmobile Bravada fuel or ignit switch probs or what?
There are several things to check related to fuel pump operation. It sounds like you have an intermittent problem so you need to determine if the voltage going to the fuel pump is consistent at the fuel pump relay. In the underhood fuse panel, right next to the fuel pump relay is a small blank, (empty) recessed terminal. It is connected, (inside the fuse panel) to the grey wire that runs to the fuel pump. When the ignition is initially turned to the RUN position, the terminal should show battery voltage for about 2 seconds and then drop to zero. It should show battery voltage continuously when the ignition is in the START position. Post your results.
You have to know how it works,
to figure out why it doesn't.
2000 Kia Spectra fuel reset switch? fathairysmurf Spectra | Cerato | Forte | Mentor 0 03-07-2010 04:34 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Rear Brakes 2000 Bravada bbusha Bravada 1 09-15-2009 06:59 PM
2000 Oldsmobile Bravada gaa9921 Problem Diagnosis 1 01-05-2008 11:52 AM
2000 oldsmobile bravada keyless remote wayneedwardsjr Bravada 1 04-14-2006 07:20 PM
