Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-09-2011, 09:56 AM
rs6er rs6er is offline
Parking Brake Actuator Lever Question
Is it possible to replace the lever connecting the rear parking brake cable to the parking brake actuator in the hub (the little splined wheel that used to adjust the parking brakes) without removing the brake backing plate (and therefore removing the axle).
John
2001 Suburban 1500 AWD 5.3L
Old 01-09-2011, 10:20 AM
j cAT j cAT is offline
Re: Parking Brake Actuator Lever Question
John
the rear backing plate can be cut so it is in two pieces. this eliminates the need of axle removal. I did this many years ago when the OEM heat shield backing plates rusted because GM painted over the rusted metal .. causing these to be useless..
why does the park brake dog ear need replacement ?
what do you mean USED TO ADJUST THE PARK BRAKE SHOES ?
Old 01-09-2011, 01:33 PM
As I understand it, I the answer to my question is no, unless I cut the backing plate. I replaced the backing plates about a year ago by removing the axles. Before I installed them, I used every Eastman rust preventative coating under the sun to prevent them from rusting out again, so I am not anxious to cut one of them (the right one) up.
The dog ear needs to be replaced because it is no longer there. Not sure how that happened, but it did. I am also having a hard time finding a replacement without buying an AC Delco hardware kit for $65 from an aftermarket supplier (the dealer wanted $130!). I did a junk yard search but couldn't come up with one.
If I did cut the one off that is on there now, I would replace it with a 2-piece one that Dorman makes.
Old 01-09-2011, 03:25 PM
I guess I was not clear with my explaination..the OEM heat shields did not need to be cut to be removed as they where very very rusted..basicly fell off..
bought new heat shields , cut new shields so they are now 2 pieces. mounted the heat shields with no axle removal..coated the shields with rusfre brush on undercoating compound. no problems..
since you are aware of these 2 piece heat shields that are available, copy the design and do it..
operating with only one parking brake for a time is no big deal..soon the scrap yard will have the part you need.
so the scraping noise was the park brake shoe adjuster ...?
Old 01-09-2011, 05:36 PM
I did understand what you meant. I'm not sure I could cut one off and reuse it in a 2-piece configuration. It would be a lot easier to cut one when it is off the car. In any case, I can get a 2-piece Dorman for about $14. No point in doing that until I can find a dog ear though.
The dog ear was missing from the right side. That wasn't the side that was making the noise.
While I have you, I got a hardware kit (without the dog ear). I can't figure out where the piece whose picture I have attached goes.
Old 06-03-2013, 01:59 PM
gandolf567 gandolf567 is offline
Hello. I am in the same exact situation as you. I know its been a while, but can you share your solution? I'm having trouble locating this little lever as well. Was the little lever all you needed? And how does it install? Thank you.
Old 06-03-2013, 02:42 PM
I never got it. I know it's part of a Delco kit from the dealer.
Old 06-07-2013, 10:29 AM
Thanks. You're right. I just got it. It was a parking brake and hardware kit. It's kinda dumb that they won't sell the lever individually.
Old 06-07-2013, 10:38 AM
I think you have to take the brakes, etc. off to install it. Keep us posted.
Old 03-02-2014, 08:12 PM
slider85 slider85 is offline
Ever complete this repair? I am contemplating it after just dealing with it for several years.
Old 03-03-2014, 08:04 AM
I purchased the Delco kit and had a mechanic complete the repair while he was doing rear calipers and rotors.
Old 03-03-2014, 02:25 PM
Do you have a part number for the kit?
Old 03-03-2014, 03:16 PM
I'm pretty sure I bought it from Rockauto but can't find the invoice or the item on their website.
parking brake vs. car in park...help! CVCchic85 '96-'00 Civic 1 08-09-2010 09:56 PM
Parking brake tbird -92 5.0 bennylw Thunderbird 4 06-14-2009 03:24 AM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
96 Parking Brake Lever Not Fully Releasing barker23 C/K 2 12-16-2004 05:09 PM
Parking Brake Lever Beyond Imagination Car Audio 11 01-20-2002 08:27 PM
