Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-07-2011, 08:38 PM
mishalah's Avatar
mishalah mishalah is offline
door light not working
Where is the switch or fuse for the driver door courtesy light??? All others work fine, not driver door. 2005 K1500 LT.
Old 01-07-2011, 11:26 PM
danielsatur danielsatur is offline
Re: door light not working
It's probably just a bad bulb in the door.
Old 01-08-2011, 02:57 AM
mishalah's Avatar
Uhhhhh, no. None of the interior lights come on when the driver door is opened. They will come on when any other door is opened. There has to be a switch somewhere to activate the lights from the driver door when it is opened.
Old 01-08-2011, 12:53 PM
The switch is probably built into the door locking mechanism.
see http://www.alldata.com
Old 01-08-2011, 02:53 PM
j cAT j cAT is offline
this is great material if you are a fleet tech / etc...
my opinion this alldata is way too expensive for simple repairs like a door light..
Old 01-08-2011, 03:39 PM
the problem is ,,,, driver door open no interior lights ?
when the other doors are open no problem ?
If this is the condition the mini wedge driver door jamb switch is bad or the wires are open to it..
the grounding out of this wire with the door open grounds the bcm input ..the bcm then turns on this interior lights..
this door switch is in parrallel with other switches , so the bcm is not defective..
Old 01-08-2011, 05:48 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
This site takes you to both Full and the DIY subscriptions.
Might want to add the DIY
www.alldatadiy.com
MT
Old 01-08-2011, 05:59 PM
MT-2500's Avatar
AF - Advisor
Also the old Ford pickup fix lube the door latch may help.
MT
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
dash lights out & automatic lights not working bbfalls Toronado 4 10-19-2010 05:51 AM
2003 Sable blend door actuator not working rdhaley Sable 1 03-02-2010 09:00 PM
Tail lights not working when not in use? duhlikemanda General Discussion 2 02-28-2009 05:38 PM
Dome, Trunk and Door Lights not working 01naleganza Leganza 0 02-19-2007 01:38 AM
