Old 01-06-2011, 02:30 PM
lkappes lkappes is offline
04 GTP loss of boost
Last night I was driving home from work and notice a loss of power. I turned on the boost gauge and it only read boost if I jumped on the throttle, and even then it was only about half for a second or two. The car doesn't seem to be running any different except for that.
I have read all I could find and I am thinking that it may be a loss of vacuum or a stuck bypass valve.
Any ideas? The car has about 160k miles if that matters.
Old 01-06-2011, 06:27 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 04 GTP loss of boost
Make sure the belt is good on the supercharger.
Are you sure your losing bost, or is the guage lying to you? I am unfamiliar to the series III 3800SC motor, but on the Series II, there is a sensor that measures boost. The vacuum line that leaves the bottom of the lower intake manifold on the passenger side of the motor, supplies vaccum/boost to the sensor. If your motor has this vacuum line, make sure its connected and not cracked.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-06-2011, 08:02 PM
Seems like I am down on power, but I am not sure if it is the gauge or an actual loss in boost. I will check the belt. I tried looking and all hoses look ok, but I didn't have very good light.
GTP Anti-Freeze Leak bbaker1985 Grand Prix 2 04-03-2009 05:35 PM
GTP Question Please Help bbaker1985 Grand Prix 6 03-27-2009 04:16 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
lossing boost? 95DodgeAvenger95 3000GT/Stealth 12 08-29-2007 07:50 PM
TPS Code/hesitation/power loss/boosts good one1fasteclipse Eclipse Problem Diagnosis 5 08-19-2007 10:14 PM
