Old 08-29-2007, 03:17 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
lossing boost?
why does my car hit its max psi and start to drop so much? am i getting a leak somewhere or do these cars just loose boost that quick? or is my boost gauge shitty? i have an aftermarket boost gauge in the car so its not the shitty factory one. when does your guy's cars start to lose boost?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 08-29-2007, 03:23 PM
new2mitsu new2mitsu is offline
Re: lossing boost?
usually i'll hold at least 7-8 pounds all the way to redline in 1st, not sure after that tho
Old 08-29-2007, 04:19 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: lossing boost?
Hey bro.. I am glade you have come to AF Cause the more the better but every other thread is one that you started and there all single question's that is almost always answered in the FAQ section here is the link
http://www.automotiveforums.com/vbul...d.php?t=301872
It's a great read and I am sure you will learn alot! if you still have questions after reading that then try out the search button.. I know there are times its easyer to just post the question (I even am guilty of this) but I look for an answer most of the time..
Jason
sorry.. kinda in a bad mood work sucks
Old 08-29-2007, 04:23 PM
Re: lossing boost?
Jason
well everytime i go to the faq page none of the links work or anthing. so i kinda dont bother to look. so sorry i post so much ill quit posting shit.
Old 08-29-2007, 04:47 PM
jason_bet's Avatar
Re: lossing boost?
naw don't stop posting.. Im being an ass sorry.. yeah the turbos that are on our cars stock will run about 9-12 psi to red line but most will only to about 10.. what are you holding to redline?
Jason
Old 08-29-2007, 06:27 PM
Re: lossing boost?
Jason
well according to my new boost gauge i hit my 12psi then drop to about 5 till redline, thats according to my gauge. is it possible that i have a leak that dont leak till i like hit my max psi then it lets it leak? or what could be goin on
Old 08-29-2007, 06:32 PM
jason_bet's Avatar
Re: lossing boost?
posible yes.. but your car would run like crap!! does it backfire? or feel jumpy? how is your guage hooked up?
Jason
edit.. have you installed your MBC yet?
Old 08-29-2007, 06:46 PM
Re: lossing boost?
Jason
Have not set up my mbc yet its on its way here still. i have the boost gauge line T'd into the small hose on the back of the manifold, then it runs up along the fire wall to just b4 the driver side shock tower has a loop, then down into where the hole is in the fire wall and up under the driver side counsole and up to the top of the steering wheel cover thing. lol if u would like ill get a pic of the line from under the hood and where my gauge is mounted. it dosent seam to backfire i can feel it lose power tho after it peaks, its still fast but i feel it letting up. also one more question. does the car not hit boost when revving? bc when i rev and watch my boost gauge it reads 0 no boost but when im in gear and driving it gives me boost readings. thanks for the help and sorry for all the posts i get outta hand sometimes, i get jumpy and cant help my self.
Old 08-29-2007, 06:53 PM
jason_bet's Avatar
Re: lossing boost?
HAHA I no what you mean.. yeah post a picture and If I had to guess I would say its prob your factory boost solinoid.. but you will be bypassing that when you install your MBC so I wouldn't worry to much about it right now untill you install that..
yeah you won't really build boost cause there is no load when your clutch is in.. if you hold your foot to the ground and let it bounce off the rev limiter it will probably build a pound or two..
Jason
Old 08-29-2007, 07:05 PM
Re: lossing boost?
Thats how its set up. =/
How bad is it on these motors to let it bounce off the revlimiter in neutral?
Old 08-29-2007, 07:26 PM
Hotshot8792 Hotshot8792 is offline
Re: lossing boost?
You have a boost leak somewhere. Its not uncommon for this to happen.
If you said you were hitting 12 PSI and then only holding around 9 PSI to redline like in 2nd and 3rd gear, I would say your fine and thats perfectly normal. Our turbos are so small they can only hold about 9-10 PSI to redline, and sometimes up to 11 or 12 if you have a downpipe, aftermarket exhaust and every other mod you can have to open up breathing for your turbo.
But since you said about 5 PSI (especially since the wastegates are set at 6), you definitely have a boost leak somewhere. It may not have anything to do with your boost gauge install, but you can double check the connection where you T'd it off and at the connection at your boost gauge.
Another good way of testing for a boost (vacuum leak) is to see what your gauge reads in the vacuum area. When you are idling and sitting still, you should be reading about -20 on the vacuum side. When your driving and you let off the accelerator completely, it should drop below -20 and work its way back to -20 as you come to a stop.
When you get your boost controller, I would recommend doing the vacuum reduction mod, if you haven't already. There's step by step instructions on 3SI, but I can't link you to it right now because appearantly 3SI seems to be down at the moment. This will eliminate a lot of places where a boost leak could be occuring.
If all else fails, pressure test.
Edit: Just saw your picture. I really can't tell by that picture. If you look here http://www.3sx.com/store/comersus_vi...dProduct=24072 the plenum on the left (TT plenum) you can see two nipples coming off it on the upper left side. Tapping into either one of those will work just fine. Sorry I can't find a better picture of it right now.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-29-2007, 07:33 PM
jason_bet's Avatar
Re: lossing boost?
I can't tell what is going on in that picture.. got a differant one?
umm.. i wouldn't recommend doing it.. a lot. haha
Old 08-29-2007, 07:50 PM
Re: lossing boost?
well it does read -20 in vacuum and it does drop a lil bit below that when i let off the gass not alot tho just a lb or 2. it might hold 6 at redline. its just so close to the 5 that i didnt really check to see if it was like dead on 5 or not but ik its like rite there. see if this link helps see it.
http://img201.imageshack.us/img201/4...9071957bu9.jpg
