Old 01-05-2011, 11:21 PM
hunter4ever12 hunter4ever12 is offline
Installing headers
When installing headers on my 5.0 L K1500 is there any special precautions I should take? I talked to a fellow mechanic at work and told him I was putting headers on my pickup and he said not to because he put them on his El Camino and they "melted everything." What do I need to do to prevent that from happening.
Also when putting on the headers is there a place to screw in the oxygen sensors on them or am I going to have to modify that set up in some way?
Old 01-06-2011, 11:50 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Installing headers
You can reduce the heat emitted by buying headers with a ceramic coating. Also make sure that all wires and hoses are held clear of the hot surfaces by using zip ties. Do not use the header heat wrap as these can retain water and cause rusting of the header.
Most headers do come with the welded-in bungs needed to install O2 sensors, so no need to fuss with them yourself. Just verify that what you are buying is for your vehicle year and engine...most will have a bung for each bank for the pre-cat sensors, but if your truck is pre-1996, you won't need them since the single bung is located in the y-pipe...just leave the plugs in.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-06-2011, 12:10 PM
j cAT j cAT is offline
buy the ceramic coated headers. then if you find too much heat in the engine compartment use the wrap. the ceramic coating will prevent rust anyway...
when headers are installed the rapid exhaust cooling can reduce power by increasing exhaust back pressure.. with insulation this is eliminated..don't need much to achieve this..
using plug wire heat loom with this 5.0L may also be needed...
Old 01-06-2011, 12:21 PM
Scrapper Scrapper is offline
AF Premium User
my nephew just sold a brand new pair of ceramics he put them on graigs list i think he sold them for $80.00 if i new hew was selling that cheap i would've bought them.
Old 01-06-2011, 06:35 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Also when buying headers, pay attention to how they block the spark plugs/plug wires. With headers, chances are you are going to have to use a wrench instead of a spark plugs socket and ratchet.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
backfiring problem after installing headers sh0ckerturb0 C/K 1 05-11-2004 11:18 PM
has anyone installed headers and catback? 00tegra Integra 12 04-22-2004 01:46 AM
Engine check light after installed Headers StealthSonic Accord/TSX/Accord Hybrid 3 02-19-2004 01:51 AM
Need help installing header crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-09-2003 09:35 PM
Installing header on 4th gen Rusted_Nailz Accord/TSX/Accord Hybrid 6 02-26-2002 02:45 AM
