Old 01-05-2011, 01:53 AM
Dbanks12 Dbanks12 is offline
Heater problems
Have a 94 Park Avenue that has a electronic heater in it, replaced the alternator a week ago and now the car warms up fine, then the temperature numbers start flashing and it goes to cold by itself. Tried turning it off, turning the temp up and down and it stays on cold or heat on the drivers side and cold on the passenger side. I'm stumped, tried disconnecting the battery cable again and letting the computer reset itself but it still does it, any ideas would be appreciated..car has a new rad and thermostat in it as of two weeks ago, tons of heat when it works!!
Old 01-12-2011, 11:20 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Heater problems
I assume, when you you changed the alternator that you also disconnected the negative (-) battery cable first, but did you turn the A/C controller OFF first (with engine running) before disconnecting the battery cable? If not, the controller lost it's calibration and would need to be re-calibrated using a TechII scan tool. If you are patient, (and have a big coat & gloves) the system will usually reset on it's own after about 50 ignition cycles (engine starts with time delay for system to try re-calibration).
98 Park Ave Heater Problem! Firemanemt1970 Park Avenue 5 12-05-2010 03:02 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 05:24 PM
Heater problems/A/C problems Dan521 Crown Victoria 2 02-07-2006 08:04 AM
86 325e heater problem maxmuscle 3 Series 1 01-30-2002 06:10 PM
