Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-02-2011, 08:36 AM
cajcompany cajcompany is offline
No compression in 4 of the 6 cylinders in a 95 3.1l engine
I have a 1995 Buick Century that overheated and blew a head gasket. The vehicle ran and I pulled the heads and had them resurfaced. When I installed the heads and tried to start it it did not run. It has gas and spark. I checked the compression on the front 3 cylinders. They have 0 compression. I pulled the valve covers and checked the pushrods on the rocker arms. The push rods are in the proper location. I checked the compression on the back 3 cylinders and 1 and 3 have 120 PSI and # 5 has 0. I am thinking the timing chain and sprockets have jumped a tooth or 2. Any ideas.
Old 01-02-2011, 08:49 AM
Scrapper Scrapper is offline
AF Premium User
Re: No compression in 4 of the 6 cylinders in a 95 3.1l engine
did you tighten the bolts in the pattern there supose to be when replacing?
Old 01-02-2011, 11:59 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
If its just the valve timing, then all the cylinders should still have a similar reading.
Try spinning the engine over with both valve covers off (by hand is best) and observe the valve gear. Do all the valves go up and down the same amount?
Also, take a close look at the top of the valves and springs. Make sure the valves and keepers are still in place. It's possible some of the valves have dropped.
Old 01-02-2011, 04:29 PM
Yes I tightened the head bolts as per OEM recommendation with new head bolts. The valves all open and close. I can not index #1 cylinder to verify TDC. I have backed the rocker arm nut of a little on the 0 compression cylinders and they jump up to around 150 psi.
Old 01-02-2011, 04:59 PM
Blue Bowtie's Avatar
Registered Offender
How much did the machinist remove from the heads? If it's much more than a 0.020" cut the push rods may be too long. The Chevy V-6 has a very sensitive valve train, an lifter plunger travel is only about 0.080" total maximum.
If the cut was lighter than tah, your lifters may have pumped up. They should self-adjust once the engine is running and oil flow/pressure is normal.
Old 01-02-2011, 10:09 PM
Dont know how much was cut from the heads. If the cut was more than you specified how can I compensate for this?
Old 01-03-2011, 08:16 AM
snshddog snshddog is offline
I have run into that many times. Seems the lifters get pumped somehow with the pressure off. Take the front valve cover off and losten the rockers a couple turns. engine should start, tighten each rocker slowly as they start to tick back down to their stops. will run rough for about 5 minutes then smooth out and all good after that.
Old 01-03-2011, 09:09 PM
Thanks for the input everyone. I have heard of lifters collapsing but not pumping up. I will give it a try.
Old 01-04-2011, 07:17 PM
Does any one know what causes these lifters to pump up and hold a valve open?
Old 01-05-2011, 06:22 AM
Not sure what causes it but I have done tons of those head gaskets and it just seems to happen 1 out of 10 times. Did that fix it?
Old 01-08-2011, 12:42 PM
I finally got a chance to work on this car today, I finally got it running, the only problem now is 1/2 the lifters are not oiling the rocker arms. Ran it about 10 minutes, changed the oil and ran it for another 5 minutes still no oil to these same rocker arms. I would put it back together and run it but Ii need to ensure the rocker arms are oiling.
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
Any significant differences between 3.1L engine and 3100cc engine wildman334 Regal 2 02-09-2005 08:36 PM
3.1l Engine Swap Questions And Concerns JAMES-Z24, MONTE Engineering/ Technical 1 02-14-2004 07:59 PM
3.4L to 3.1L engine swap? browning1919 Lumina 2 12-28-2003 01:44 PM
NEED Big help with 92 3.1L Engine Hesitation Please cp___32 Cavalier 3 12-09-2003 01:23 AM
