Old 11-20-2003, 05:37 PM
cp___32 cp___32 is offline
NEED Big help with 92 3.1L Engine Hesitation Please
Hey everyone!
I have a 92 Cav 3.1L With over 300K KM on it.
I'm not sure of the service record of the vehicle, however since we've gotten the car it has develloped a drivability problem. The car backfires as you try to start it, upon starting the car it usually runs well, but once it is warm the car begins to hesitate severly, sputter, or completely stall. Giving the car more/less throttle does not help the car, and in fact, when the car does this it almost does not recognize throttle input at all. I have a feeling it's sensor related, but don't know enough about the engine to know what to test or what to look at. The oil pressure gague also tends to go real funky and sways back and forth when this happens. We have replaced the plugs and the O2 sensor to no avail. I have heard of this being a cat. converter problem, however there seems to be no flow problems.
Any help would be great to help the car roll closer to the 1M KM Mark. Thanks!
Old 11-22-2003, 08:13 PM
loco_k0pykatz loco_k0pykatz is offline
Re: NEED Big help with 92 3.1L Engine Hesitation Please
Well seems to me that the IAC Idle Air Control Valve is not working, just replace it and you should be fine if that fails you need a new ECM computer.
Old 11-28-2003, 10:46 AM
mikeybart mikeybart is offline
This may not sound right but bear with. Mine also has 300K on it and it started running rough. What it was is a hole in the rad cap caused the rad to suck air into the system. When this occured air pockets in the system would hit a coolant temperature sensor and trick the computer into thinking that it was -20 F and the computer would richen up the mixture to warm up the engine. The fix is to go to a 20 min oil change shop and get a rad flush and to get a new rad cap.
Old 12-09-2003, 01:23 AM
thecommi thecommi is offline
Send a message via AIM to thecommi
The suggestion on the Idle Air Control valve is a good start. If you replace that and the car still wants to do what its doing, I would suggest replaceing the Ignition Module or coils. They tend to go bad overtime causeing some really strange things to happen with starting, idleing or drivein in general.
how do i replace front struts on a 92 eurosport with 3.1l engine rta222 Lumina 1 11-08-2009 10:48 AM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
Need some help with a 1996 eagle talon!!! PLEASE HELP talon_17 Off-Topic 1 10-02-2006 06:47 PM
Need big help with 95 motor into a 97 Corollamotorblower Corolla/Matrix/Voltz 1 08-01-2004 12:22 AM
need big help with a 98 jetta liviu26 '97 - '03 0 06-26-2004 02:42 PM
