Go Back   Automotive Forums Car Chat > Oldsmobile > Toronado
Old 01-01-2011, 08:13 AM
mn_1 mn_1 is offline
Talking 85 Toro Brake problem
Car has 4 wheel disc brakes. When you start it up the pedal goes all the way down. After a pump or two it comes up most of the way. Then it seems okay until the next day, then repeats. Master cylinder is my suspect. The master is full and inspecting the calipers I saw nothing obvious nor any leaks. Front calipers are cheap but the rears are quite pricey. Brake light in dash does not come on. Any suggestions?
Old 01-01-2011, 08:25 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 85 Toro Brake problem
I would suspect the master cyl as well, most likely it has an internal leak
Old 01-03-2011, 02:28 PM
maxwedge maxwedge is offline
A990 racer
Check the rear calipers for being frozen or out of adjustment, pumping the parking brake was one way to bring up the rear caliper setting.
Old 01-03-2011, 08:37 PM
Talking Re: 85 Toro Brake problem
How do you check the adjustment/setting on the rear? The pads were all snug against the rotors when I inspected them. You start the car and the pedal goes all the way down and comes up after a pump or two. I told them not to use the park brake.
Old 01-03-2011, 09:15 PM
MagicRat's Avatar
Most rear calipers that I know of require regular use of the parking brake to maintain proper adjustment.
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 09:14 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 02:41 PM
Braking Problems frehleycomet Tracker 2 03-29-2009 10:46 AM
92 toro running problems rairigh915 Toronado 3 09-20-2007 08:31 PM
1991 Cougar brake problem. Brake Relay? psiege Cougar 1 01-20-2003 06:09 PM
