Old 12-31-2010, 06:52 PM
gpn50 gpn50 is offline
2000 f150 v-6
My check engine light on. I had the codes read ay autozone and are as follows.
PO171 fuel to lean bank 1
PO174 fuel to lean bank 2
I have changed the egr valve appx. 1 year ago after a PO402 code (excessive flow)
I have checked all vacumn lines and replaced the pvc valve once already and would apprecate any advice.
The engine pings at times and I notice that the rpms somtimes increase at idle from 900 to about 1200rpms.
Other than that it runs great.
Thanks in advance!
Old 12-31-2010, 07:11 PM
danielsatur danielsatur is offline
Re: 2000 f150 v-6
1) Do a smoke test for unmetered air from EGR, PCV,and Air intake system.
2) Did you clean the Massive Air Flow(MAF) with CRC MAF sensor cleaner.
3) Replace upstream H02 sensor.
Old 12-31-2010, 07:46 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2000 f150 v-6
1) yes
2) Good possibility
3) Probably not the problem. More than likely if it is not the MAF, it will be a vacuum leak.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
f150 4.6 overheating JoeB64 F Series 3 02-06-2010 09:29 PM
HELP!!! 1984 f150 straight 6 won't start!! rodj_1 F Series 6 01-01-2007 02:27 PM
97 f150 4.6 won't start when cold dbarker4322 F Series 1 02-05-2005 06:22 AM
Accelerator shaking on 96 F150 I-6 Cait Sith Cat F Series 1 01-23-2005 04:23 PM
Late 80's f150 300-6 jonnyhammer Escort 1 12-09-2004 05:05 PM
