Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-29-2010, 09:10 AM
chilsonj chilsonj is offline
Exclamation Where to start...
Alright here are the problems I have with my 01..thanks to the so called "friend" who sold it to me.
1) My headlights hesitate to turn on, I have to wait a few minutes. Same goes when I turn them off. The high beams act the same way.
2) The interval wipers act up when I want 1 wipe I get three, the rear one? Forget about it that thing doesn't even shut off unless you disconnect the battery.
3) After turning the key on the prolong beep won't shut off for a while, same goes when you turn it off.
4) I can only open the power windows from the driver side master panel.
5) I am getting a rumble from my left front wheel mainly when I turn to the right.
6) On the highway starting around 65-70 MPH the reaer end cavitates like a terribly bent rim. The tire places noted the rims looked okay and so did the brakes.
When I got it this "buddy" installed an aftermarket remote start and also installed satellite radio. I tore the satellite radio out but the not properly I think the wires are still exposed. I beg for some help here!
Old 12-29-2010, 12:04 PM
mopar96 mopar96 is offline
Re: Where to start...
The rumble is a hub bearing going out, easy to replace. As far the rear end shake, are the tires balanced right, maybe drive shaft lost it weight also...
Old 12-29-2010, 01:34 PM
Noted, i'll replace the hub bearing. When I got it I had to spend over $1000 on four new ball joints just to get it inspected. You think $6,000 was too much for this purchase with all that is wrong with it? I'm at a loss with the electrical, the positive end of the battery has a blue dry/gel substance on it...which rose an eye brow. Could it have anything to do with the after market remote start or the hot satellite radio wires?
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 10:45 AM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 08:28 PM
2003 Malibu starts but stalls immediatly? the_unicycle_guy Malibu 21 07-25-2009 12:48 AM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 08:24 AM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 09:52 PM
