Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-28-2010, 02:28 PM
jmike575 jmike575 is offline
04 4.7 in a 02 1500 4x2
I have a 2002 1500 that blew the engine and got a good deal on a 4.7 out of a 04 so its installed now and does not start. I have 2 codes p1391 intermittert loss of cmp or ckp and p0340 no can signal at pcm. On my modis I can read can and crank signal i checked the 5 volt ref and its good along with a good ground and signal from the cam sensor. any ideas guys?
Old 12-28-2010, 03:56 PM
Re: 04 4.7 in a 02 1500 4x2
Just to let yo guys know i found the problem. 03 and 04 will work but 02 is differnt. its the crank target wheel. one has a 32 pin wheel ant the other has a 16. only way around is to change harness and pcm
Old 12-28-2010, 10:58 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thanks for the update and info jmike, that one had me stumped.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 10:22 AM
2002 dodge ram 1500 4.7 engine chief1123 Ram Pickup | Ram SRT10 2 09-04-2008 11:57 PM
dodge 1500 4.7 buckshot1819 Engineering/ Technical 2 08-04-2008 01:59 AM
05 Ram 1500 4.7 timd Ram Pickup | Ram SRT10 0 05-17-2007 07:36 AM
2002 Ram 1500 4.7, Weird Sounds condor63 Ram Pickup | Ram SRT10 3 02-25-2005 04:26 PM
