Getting ready to change my 2005 Odyssey sparks plugs. Anybody change theirs as they appear to be hard to see. Can they all be done from the top? This is the first time as I am coming up on 100k.
Re: 2005 Odyssey Plug change
They are simple, well pretty easy.
Get the plugs from Honda! Make sure engine is cool - key off Remove front engine cover Remove top engine cover Unplug 6 coils Remove 6 allen bolts Left out coils - the back 3 are harder Remove plugs and re-install You will need a variety of extensional because a long one is too long in some spots and shortys are too short so 2 3" extensions work well. Drop the socket down in the hole insert extensions, then separate to remove for spark plug tube. A magnet will aid in remove of plugs once they are loosened. Make sure to tighten them enough to where the crush washers crushes. I don't torque them but I also work on them every day. |
| The Following User Says Thank You to BullShifter For This Useful Post: | ||
dra1 (03-15-2011)
I have on 03. The plugs aren't difficult to replace. The back ones will necessitate a bit of creativity to reach but nothing major really. I also got the Honda plugs... it's nice cause they are pre-gapped but they charge you dearly for the plugs. All in all probably a half hour job.... unless you open up the beer prior to finishing the job... then all bet's are off with the back plugs.
| The Following User Says Thank You to badbrakes For This Useful Post: | ||
dra1 (03-15-2011)
Finally changed the plugs. Thanks for the advice. It took about an hour as I took my time. Very good advice about the two 3 inch extensions. Thanks again.
Also got my plugs from NAPA, the Honda garage wanted about $25 each, NAPA charged half that. Last edited by dra1; 12-27-2011 at 03:09 PM. |
