Old 12-28-2010, 11:45 AM
dpalomaki dpalomaki is offline
No heat (no air blowing)
This is an informational post. Could equally effect A/C in warm weather.
2004 LeSabre Limited, about 98,000 miles.
Symptom - no air blowing from the heater vents at any fan speed setting.
The two involved fuses were found to be good.
Conncting a test light at the motor power supply terminals showed power was being delivered to blower
Tapping the blower motor would cause it to work for a couple days.
Replaced the blower motor (about $55 for the OM part at Amazon) and all is happy.
Took the old blower motor apart, found brushes worn down and a build-up of a black fuzzy stuff (maybe worn brush material) in the motor housing. Dirty stuff in any case.)
No air flow from vents, blower fan running ts1653 Windstar 5 07-19-2014 02:02 PM
'01 Cougar No Air flow 99% of the time need heat and live in WI goldsun767 Cougar 0 10-15-2010 05:27 AM
94 APV 3.8-No heat, no air...nothin'-HELP apvtrvlr Lumina APV 6 01-09-2009 02:26 PM
No Heat/no Air Con/no Defrost crash69 M Bodies 5 03-14-2004 09:14 PM
got heat, no air blowing zgraum F Series 0 01-03-2004 02:35 PM
