Old 01-09-2004, 09:01 AM
crash69 crash69 is offline
No Heat/no Air Con/no Defrost
1999 Chevy Astro. The Heat, Air Conditioning And Defrost Does Not Work. None Of The Fan Settings Work. Its Like The Whole Panel Is Shot. If I Leave The Fan On High, And Put The Heater On, And Drive Around, Sometimes It Will Kick In. But Lately No Such Luck. Basically None Of These Features Is Working At This Time. Any Ideas??? Loose Connection? Fuse?
Help!
Old 01-09-2004, 02:14 PM
RABarrett RABarrett is offline
Re: No Heat/no Air Con/no Defrost
I would check for both voltage and ground to the panel, in the correct places. You might have a blown fuse. If so, you will need to find the short. If you don't, the problem will recur. Ray
Old 03-06-2004, 06:05 PM
3800wattvan 3800wattvan is offline
Uturn1200
no heat/air/defrost
Don't think this is relevent because my fan motor worked at the time. My A/C stopped working last summer and I found that the hard plastic vaccume hoses broke. It still blew air but it was hot and humid. I bought black rubber hose that would slide over the factory plastic. Worked great but hard to get into the back of the engine. Now the heat is briefly blowing COLD but returns to hot. I suspect the same problem since I didn't replace all the plastic tube at the time.
Old 03-12-2004, 11:13 PM
pringlemr pringlemr is offline
Check your blower motor resistor. Look for the blower motor under the hood on the left by the A/C stuff. Near the blower motor ductwork you should find a wiring harness going into a rectangle plug (1/2"x3"). Pull this out. I have had part of this go bad on our 97 astro, we lost the lowest fan setting. If the whole thing is shot you could lose all fan settings. $40 dealer only item.
Old 03-13-2004, 09:36 AM
Andy&Eye Andy&Eye is offline
Had the same problem with our '93, and after trouble shooting endless miles of wire, finding nothing wrong, I changed the blower motor, and everything works just fine....
Old 03-14-2004, 08:14 PM
bduff509's Avatar
bduff509 bduff509 is offline
I just had the same intermittent problem with my '94 Safari. I replaced the blower with one from an '80 F-bird. Works fine except the little hose from the blower to the motor does't match.
No air flow from vents, blower fan running ts1653 Windstar 5 07-19-2014 01:02 PM
'01 Cougar No Air flow 99% of the time need heat and live in WI goldsun767 Cougar 0 10-15-2010 04:27 AM
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 09:09 PM
2004 Bonneville - No air flow to defrost or floor reedj66 Bonneville 0 12-02-2009 09:47 AM
99 Jeep GC: no air flow from defroster cbehr Grand Cherokee | Grand Cherokee SRT8 0 08-23-2006 03:26 PM
