Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 12-26-2010, 10:29 PM
heydawgg heydawgg is offline
2003 Odyssey - Front (right-side) bumpy vibration
Any idea what might cause a bumpy ride/vibration on right-side of my 2003 Odyssey? Have had the wheels balanced....feels like a suspension problem...I've also heard motor mounts can go bad on these vehicles?
Old 12-29-2010, 06:15 PM
BullShifter's Avatar
Re: 2003 Odyssey - Front (right-side) bumpy vibration
Yes mounts go bad but that wont affect the ride. Is the strut leaking? I have seen the Ody's blowing out front struts.
Old 12-29-2010, 07:41 PM
Thanks Bullshifter, that's exactly what I believe is the problem now.
I removed the two front wheels again, and took both to a shop to have balanced....both were in balance...no issues.
I took a look at the struts, and just under the rubber boots, it looks like a sheen covering the strut...which looks like a leakage in my eyes...both struts had the same look, and when I touched that gunk, it felt oily....so guess is the struts are done.
Any idea what a shop would charge to replace those...and should I go with a heavier duty set to ensure it doesn't happen again.
Thanks!
Old 12-29-2010, 08:19 PM
It's hard to remember every thing but I'm pretty sure the labor time is 3.0hrs for front struts + alignment. As far as struts go, if it were me I would stick with OEM stuff. The only other struts we have installed on an ODY is KYB and it sat funny. The front was very high(correct parts) but drove ok. You can check www.hondaautomotiveparts.com for prices. For just the struts they want $103.08 each while a regular dealer will charge you $147.26 each. There is another option and that's getting the fully assy which includes the strut, spring, mount, etc it's complete and ready to install not spring compressor or switching parts but it's more $$$ $268/$271 each.
Old 12-30-2010, 10:35 AM
Thanks Bullshifter,
This will give me a good "ballpark" number for when I'm talking to my mechanic....I'll probably get both sides done, just to be safe, so it's looking like a $500-$600 bill with labour included....give or take $100.
Thanks for your help on this!
Heydawgg
Old 12-31-2010, 09:50 AM
Yes definitely do both sides. It's possible the rear shocks might be leaking too, we have seen a lot of those. The rears are simple to change.
Old 12-31-2010, 01:52 PM
Thanks Bullshifter,
I'll get them to check the backs as well....guessing those might be leaking or worn (but I'll change those out myself...pretty easy to do...struts are a different animal though).
Thanks for the help!
H.
2003 Odyssey Ex Auto 2003HondaOdy Odyssey 2 11-16-2010 09:14 PM
Front Right Vibration mrupe2071 Windstar 1 07-31-2010 08:52 AM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 08:16 PM
Please Help!!!i Really Really Need Front Right Dash Area Wiring Schematic!!!!2003 Ext TMC03EXT General Discussion 3 02-03-2006 04:58 PM
Noise in front (passengers side) BlackZodiac Grand AM 3 06-17-2004 08:52 PM
