Old 12-24-2010, 10:39 AM
dakota1205 dakota1205 is offline
2000 z71 "service 4WD" light is on
After driving my 2000 z71 5.3L, the "service 4WD" light comes on. The 2wd button is lit, it will switch to 4wd, it will not switch out of this position. I keep pushing 2wd, auto buttons, nothing, still stuck in 4wd. Turn off engine, start back up, keep pushing same button, finally pushing auto button, it will go to auto, then push 2wd, it will go there.
Other times, when service light not on, all buttons work fine, it goes in and out of four wheel drive, hereing the actuators under vehicle switching.
Any ideas on what may be going on?
Old 12-25-2010, 12:14 AM
j cAT j cAT is offline
Re: 2000 z71 "service 4WD" light is on
with the service 4wd light on intermittently this is usually the dash switch. I removed this switch then re soldered the switch pins to the circuit board. takes about 45min to do ..
if it does not correct this get failure code pulled and post here .
Old 12-27-2010, 05:03 PM
4x4junkie 4x4junkie is offline
could be a dirty connection on a plug under vehicle, corrosion or loose connection. but more likely the dash switch.
Old 12-27-2010, 05:20 PM
MikeD266 MikeD266 is offline
Had a similar problem with the 4x4 shifting on my '99 Z71 5.3 a few years ago. Pulled and re-soldered several cracks in the dash PCB. Even the button lights worked after that..
Dealer wanted $60 for an entire auto-trac module. Worth the short time/effort and, assuming that it IS the dash switch, an easy fix if you know basic soldering.
Old 12-28-2010, 06:30 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
replace transfer case switch in the dashboard. $65 internet, 5 minutes job. i have same year truck, had same issue in about 2 mths of ownership. mof, drove around with toothpick jammed between swich housing and 2wd button for about 15K miles, then swapped the switch.
Old 02-02-2012, 02:37 PM
Ol'Jim Ol'Jim is offline
How do you remove the 4x4 switch panel? Any special trick required, or just pry it out? My panel appears dead, no illumination of any buttons at night, no led showing the range selected. Just in time for a BIG snowstorm!!
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
Old 02-02-2012, 07:20 PM
no led on the 4wd select switch I would check the fusess. if fuses blows again this may mean shorted wires/rodents wear or the transfercase encoder. post back what fuses blown if any .
Old 02-02-2012, 09:03 PM
ukrkoz's Avatar
simply pry it open. I, normally, start on the upper left corner of it, and give it a good tug. it pops, the rest follows clip by clip. you will need to have steering column lowered as far down as possible, and gear shifter shifted all the way down too. after it pops completely, takes some wiggling to slide it off the steering column. overall - maybe 1.5 minute job. be very careful with long narrow side of it, don't break it. though, it's surprisingly strong, I had mine off prolly dozen times.
"Service 4WD" Light Problem floydpink Sierra 18 12-16-2014 04:12 AM
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 10:06 PM
2000 Blazer Back Up Light Wont Turn On? panteli2011 Blazer 3 01-23-2010 08:23 PM
02 Silverado "service 4WD" light jsimpsonS8 Silverado 1 01-01-2010 05:10 PM
Periodic "Service 4WD" Light on Z71 wagslick C/K 15 09-03-2004 12:36 PM
