Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-23-2010, 04:09 PM   #1
MAD King
1998 Chevrolet Lumina Engine Stottering
Hello,
My engine starts stottering sometimes at 35 mph, then sometimes at 45 or 55. Engine light is not on. Spark Plugs have been changed one week ago. It also needs a little bit more on gasoline.
What can this be?
Thank you
MAD King is offline   Reply With Quote
Old 12-23-2010, 07:01 PM   #2
maxwedge
A990 racer
Re: 1998 Chevrolet Lumina Engine Stottering
I assume stottering? means misfire? If so did it do this before the plugs, a bad wire or coil can also cause this.
maxwedge is offline   Reply With Quote
Old 12-24-2010, 10:49 AM   #3
MAD King
Thank you for oyur response.
That is not a misfire I think, because the engine light would come on, right?
But your advice with the coil is good. I will change it together with the distributor cap and rotor.
Old 12-24-2010, 01:02 PM   #4
lumina_98
I'm researching a misfire code on my car presently. I'm not a mechanic so anything I say take it as guestimation. Did you change the plugs yourself? My wires were very hard to remove so you could or someone else could have damaged a wire. Gap correct? But a misfire should turn on the check engine light. I'm wondering if bad gas could cause 'stottering' and not throw a code? You said the car "needs a little bit more on gasoline"? Are you saying the fuel gauge is on empty? Fill it up but not from the Pack A Sack that might be cutting it with water. Air filter clean? I think low fuel pressure and plugged fuel filters yield random misfires which would also turn on the light. Why don't you take the car to a parts store that reads codes for free? I think Autozone will scan it. Are there engine codes that exist but do not turn on the light? I don't know but the pros here would know.
lumina_98 is offline   Reply With Quote
Old 12-24-2010, 03:01 PM   #5
maxwedge
A990 racer
You need to look at how your ign system is designed, there is no cap and rotor , you have direction ign., 3 coils, wires and an electronic control,module., research this or get help before you get into this.
Old 12-24-2010, 04:24 PM   #6
MAD King
Originally Posted by lumina_98 View Post
.....I'm wondering if bad gas could cause 'stottering' and not throw a code?
Weird that you wrote this. I filled it up yesterday with BP gasoline and the stottering is gone. Can it really be the gasoline or is it just a coincidence?
There is no error code when checking it.
Old 12-24-2010, 04:24 PM   #7
MAD King
I just found it out. Do you think I should replace it?
Old 12-24-2010, 04:30 PM   #8
jamesmetairie
if the shuttering is gone with the new gas don,t worry about it.
depending how many miles you have every car will need things like plugs ,etc. when the time comes. good luck .
jamesmetairie is offline   Reply With Quote
Old 12-24-2010, 04:42 PM   #9
MAD King
Do you think I should just ignore what it might be caused?
I am wondering why it disappeared with the gasoline from BP.
My Lumina got 170000 mls on it and almost everything was replaced recently except the coil.
Old 12-24-2010, 05:51 PM   #10
lumina_98
This car with the stottering (great word I'm adding it to my vocabulary. It's like stuttering combined with tottering and overall running terrible) is used regularly correct? Gas in a sitting unused car goes stale. If regular use you could have picked up some bad gas. If it's running smooth and no codes forget it until something real crops up.
Old 12-24-2010, 06:36 PM   #11
MAD King
UPS. Sorry, that I misspelled stuttering. lol
In German it is written stotter and thats maybe why I wrote stottering.
I always fuelled my car with cheap gasoline and last time I could not find a gasstation except the BP. I will go only to BP gasstations in the future and pay a few cents more.
Old 12-27-2010, 08:26 AM   #12
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
Mad King, were you the one who mentioned Hess Mart as to where you got your gas? Avoid them. Who knows, you might be getting 15%-20% ethanol in there. Plus water, from poorly maintained equipment.
< Techron junkie
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
kevinb70 is offline   Reply With Quote
Old 12-27-2010, 10:04 AM   #13
MAD King
< Techron junkie
Yes, but I didn't know that they had 15%-20% ethanol in. I will stick with BP, Chevron and Shell in the future and pay a few bucks more on a tank.
Old 12-27-2010, 04:37 PM   #14
MAD King
Today came the engine light on and it gives me the error P1870.
After googleing a bit I found some websites mentioned that this is a common problem on the transmission valve body. I remember now when this problem started. It started after I replaced the tranny fluid and filter, but I don't understand why.
Do you guys think that can cause the stutter ?
I also wasnt able to find any valve body part and how to replace it.
Thank you
Old 12-30-2010, 09:00 PM   #15
lumina_98
Factory manual has some words on P1870.
Power control module monitors the torque converter clutch slip by calculating the difference between the engine speed and the transmission output shaft speed. When the power control module detects excessive amount of slip when the torque converter clutch is engaged the P1870 is set.
You mention tranny fluid and filter elsewhere. Is the fluid level correct?
Not a mechanic so just reading and writing but a slipping torque converter doesn't seem to describe your earlier stottering.
1998 lumina ltz starting problems luminakid1992 Lumina 17 05-22-2011 11:55 PM
1998 chevrolet lumina ls - instrument panel obiwon Lumina 1 12-09-2010 08:33 PM
1998 Chevy Lumina Engine Problems? Engine Swap to 3.8 jonfit04 Lumina 12 11-10-2010 09:15 PM
1998 Chevy Lumina Engine Scratching/Rattling MAD King Lumina 2 09-08-2010 01:18 PM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 10:42 PM
