Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-23-2010, 12:04 AM
kaho's Avatar
kaho kaho is offline
Ideas for making this wheel
Hey guys,
Haven't been posting here for a long time! Hope everyone is doing well!
Now that finals are over and I have about 3 weeks of model building, I am thinking of doing a resurrection of my Suzuki Sidekick/Vitara/Escudo as a quick build (I am calling it quick build now, hope it remains fairly quick!) The first thing that I want to do is toss away the stock rims and tire and replace with some off road steelies and mud tires off an aoshima kit (which I also built up years ago with limited success). Here is my first challenge:
I am going to build one of these rims. The face will be made with styrene cards and I will cut off the face of the stock rims and use the cylinder for this new face.
The green colored parts will be scratchbuilt and the pink will be supplied by the old rim. The spokes are tapered 15 degrees from the vertical (Other measurements are approximate). Any ideas on how to make the tapered spokes out of flat styrene cards?
Thanks for any ideas.
Old 12-23-2010, 07:59 AM
Kurzheck's Avatar
Kurzheck Kurzheck is offline
AF Premium User
Re: Ideas for making this wheel
Not exact but this could be WAY easier...
http://tinyurl.com/23cdgsd
http://tinyurl.com/25nx2ad
Corner 5 Hobbies
Guelph Plastic Modellers Group
www.thesprue.com
Old 12-23-2010, 03:11 PM
kaho's Avatar
Yea I've been going around my LHS for these kinds of rims. They are available in a few Revell truck kits, but I just can't let myself buy an entire kit that I may never work on just to take away the rims. The rims in your link look nice, but unfortunately with shipping and conversion to CAD it would cost more than the whole kit here.
Old 12-23-2010, 06:11 PM
rsxse240 rsxse240 is offline
I don't think you understand what he's saying. Those rims should fit your tires from the escudo. they are a standard 15 inch rim and like you said, they are offered in a hundred kits from revell, monogram and other US makers, as well as other models. If you were to pay for shipping, I will give you a set that is in the Rev. Mono. Jeep model I have. They aren't perfect, but if you plan on painting them white, like most of them were originally on 1:1 vehicles, I think it would be better to detail them up a little as opposed to spending all that time milling/scratchbuilding a wheel that already exists.
The tire that you have on your escudo will likely fit these rims perfectly, as has been the case of most of my experiences with aoshima/fujimi 15" tires and mono/amt/rev rims.
If you are dead set on making this wheel from scratch, I'd suggest turning the center out of one piece on a lathe and cutting the holes out rather than trying to put a bunch of pieces together. you'll have a better chance of getting it right and all the spokes at the proper angle. Then I'd only make 1 wheel and make copies in resin.
Old 12-23-2010, 07:39 PM
cinqster's Avatar
cinqster cinqster is offline
Totally agree! I'd also make a rotatable template for cutting the holes too. Just make one hole in the template and mark the wheel centre with the correct degrees to step it round to each following hole position. If you made ten wheel nut holes in the template you could even pin it in place on the centre for making each hole, or you could drill just one wheel nut hole in the template and use that to make each wheel nut hole on every second position...ah ha!
Old 12-23-2010, 08:05 PM
garnet_garnet garnet_garnet is offline
Oldtimer Newbie
looks pretty close to these rims i found at local hobby shop (can't remember name, was an asian company $2 wheel set 1/24)
Old 12-23-2010, 08:26 PM
Oldtimer Newbie
why not commision one of the long-term members on the forum here, who has a lathe to cut a set for you
Old 12-23-2010, 08:39 PM
rallymaster's Avatar
Did someone pay attention to the fact that the rim designed by kaho shows 10 holes between spokes whereas all links and advices are for a 8 one...??!
Maybe that's the reason of his particular demand...
Just my thought...
Phil
Old 12-23-2010, 09:23 PM
Oldtimer Newbie
glad you can count, cause reading owns you says "pretty close" and wasn't advice to get, and thus suggestion #2 to commission someone to make...hmm, reading comprehension
Just my thought...
Old 12-23-2010, 11:52 PM
"reading comprehension" ??
Hey you, as you want to be funny, just a guess:
How is a 8 holes so "pretty close" to a 10 one, or perhaps are you a kind of modeling magician...??
What will be really funny is to see you make the one design from the "pretty close" one given...
I don't think that someone who takes time to draw his rim, plans to sratchbuild it and ask here for advices hasn't many things to deal with your "pretty close" rim... And that's not "reading comprehension" but modeling comprehension, if you even know what it is.
uhh yes, another thing more... You're not alone here, you may feel a bit rejected or misliked these Christmas days to react like that from "pretty close" behind your computer but don't take everything for you, other people "pretty sympathic", them, also post here and - thanks god or anyone you want - do it without inevitably having to be rude or unpleasant...!!
"reading comprehesion" he said...
yes, if that pleases you let's say I don't understand anything... better than getting angry for some who even don't deserve it...
Phil
Old 12-24-2010, 05:29 AM
klutz_100's Avatar
I don't imagine that this isn't something that you haven't already thought of but - given the fact that already seem to have a great CAD file - wouldn't it be possible to give it to a 3D printing service to have a prototype made which you could then replicate in resin?
Just thinking out loud. This isn't something I have personal experience with.
Maybe Gionc or Geronimo might add some insight as I think they have used 3D printing services in the past?
Merry xmas!
Old 12-24-2010, 05:40 AM
kaho's Avatar
I appreciate all the advices here but let's keep it friendly. Thanks to the guys who found me the sources of the 8 spoke rims, and good call rallymaster for the 8-spoke vs the 10-spoke.
At the time of drawing I was using a 10-spoke wheel rim as the subject and it is my ultimate goal. Of course, if school allows me to rapid prototype/turn this part or a good feasible scratchbuilding idea comes to mind, I could get exactly what I drew, but if I have to make my own using my usual method involving styrene cards, a dremel, PE saws, and my eyeballs (I don't have access to a lathe), or have to buy what is available in stores, it becomes a completely different game. At that point I am ready to accept some discrepancies between final product and my drawing, being limited on tools/skills/product availability.
As I was running around the city, having no luck with the wheel I want, and couldn't think out an efficient enough scratchbuilding method (3 round holes + 3 straight lines connecting them to make one triangular opening X 10 holes between spokes = 60 moves with all holes drilled perfectly) I have gone quite liberal on the amount of spokes in the final product I am getting. I still don't want a 5 or 6 spoke, but anything between that to 10 would give that look I am going for.
Once again, thanks for all the advices and care from everyone being put into this thread.
garnet_garnet: where in Alberta do you live in? The four stores I have been to in Calgary don't have anything like those being sold separately. For $2 I think it look acceptable as a base to modify from and fits the bill for my project based on an old carcass of my previously done model.
edit: Thanks klutz for the idea, and how did I forget this one thing...Merry Xmas all!
Old 12-24-2010, 09:01 AM
Oldtimer Newbie
wow, you are seriously immature...you post ignorant remarks without thinking then rant like this when it's refused...you 2nd post only proves your pathetic stature....you seriously need to GROW-UP!!
so go back to your hole and rant at the people walking by...or what ever equally tantrum behavior you obviously partake
Old 12-24-2010, 09:19 AM
Oldtimer Newbie
the rallyguy idiotic ranting aside ...
...i wasn't suggesting you use the ones i pictured, only that it looked similar to ones i found local for cheap...i actually bought them just for the tires
so if you feel you could make use of them, i'll give them to you
i'm in calgary too
low tech method, you could vacu-form the basic 'cup' shape from sheet styrene stock, then trim the o.d., cut out the spokes, and add center disks
klutz is on the same track in the suggestion of having made for you, in order to be exact
i'm sure someone could spin them from styrene for just a few dollars, then you could cut the spokes out your self from there
locally i don't know anyone, or would suggest them to you, but these items would small enough to be mailed back to you within n.a.
Old 12-24-2010, 09:25 AM
wow, you are seriously immature...GROW-UP!!
All fools think that their doctor are mad !!!
Humm... So we could also think about what's hidden behind your second sentence concerning your own behaviour...
the one who is immature is the one who use internet as an existing way while he is hidden behind a computer and only have agressive and unpleasant comments to get attention.
That's what amaze me the most finaly (being treaten of immature by you is something really funny ) but it's more afflicting than funny to know that some people only run internet to feel alive and think they are some kind of important and the center of the world (their own little shitty world for sure).
Most of us give advices and critics to a positive way, other can only come in to show they are here ! Sad... I feel sorry for your poor little double-garnet lost in your narrow minded world of recognition lack !!
Phil
Idea for Makeing a Custom Bed Cover, Is this Logical? balls_to_the_wall Fiberglassing 7 07-16-2006 12:58 PM
What was the idea behind making this car? UltimateX Skyline | Skyline GT-R | Stagea | Laurel 2 06-07-2006 05:22 AM
Closed Thread
