Old 12-21-2010, 10:03 PM
thenextyou thenextyou is offline
Check Engine Light at 40-45mph
I am having some trouble with a truck I just bought. It is a 1993 K2500 with a 350. I found that the spark plug wires were the wrong ones and that the timing was way too far advanced. I currently have it set to 4 degrees btdc. Now when driving somewhere between 40 and 45 mph and when the engine is at operating temperature the check engine light comes on. When I turn the truck off and restart it the light is off. I have tried to scan the codes but it always comes up clear. Also the truck runs great lots of power no hesitations. What could be the problem?
Old 12-22-2010, 06:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Check Engine Light at 40-45mph
Is it a steady check engine light or a flashing check engine light.
Code scanners only show present codes.
If light is not back on after a restart the code has clearer on restart.
Check for codes before after light has come on and before you turn off engine.
Or get a engine capable scanner that will read out history codes.
If you can get code no post back code no.
MT
Old 12-22-2010, 10:50 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
I thought stock timing on this motor was 0 degrees BTDC? But advancing it by 4 degrees shouldn't cause any issues if it doesn't ping.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-23-2010, 02:17 PM
It is a steady check engine light. There are also no knocks or pings. I can try bringing the timing back to 0 to see if that makes any difference. I have a 94 Sierra that is set up the same way and it is not experiencing any issues like this.
Old 12-23-2010, 06:03 PM
tblake's Avatar
In God We Trust
Hmmm, what does the lable on the fan shroud say for timing spec? And you are disconnecting the tan/black wire to put in in base timing before setting it?
Old 12-24-2010, 05:40 AM
MT-2500's Avatar
AF - Advisor
When the light comes on check for codes before you turn engine off.
Post back code no.
MT
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
