Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-20-2010, 06:17 PM
stripe stripe is offline
2006 dodge 5.9 cummins
This truck is hard to start but runs fine after it gets going (some pumping of the fuel pedal needed to start)
It is on block heater each night.
Any ideas appreciated.
Thanks
Cheers
Stripe
Old 12-20-2010, 07:10 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2006 dodge 5.9 cummins
Disconnect one battery over night then check the voltage of both batteries in the morning. Less than 12.6 volts is bad.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 12-20-2010, 10:34 PM
Thanks I will try it.
Cheers
Stripe
Old 12-21-2010, 06:09 PM
AF - Advisor
How long since the fuel filter was changed?
Old 12-27-2010, 10:05 AM
snakecan2 snakecan2 is offline
my RPS sensor caused that..
you can check codes on dash by turning ingnition on/off 3 times with in 5 sec, then codes pop up on odometer.. p191 is rps switch.. oregon injection has great prices..
Old 12-28-2010, 09:51 AM
AF - Advisor
What's an RPS switch Snake? I'm not very familiar with 3rd Gens.
Old 12-28-2010, 02:43 PM
RPS rail pressure sensor.. it checks fuel pressure before the injector pump start going when you fire up the vehicle..
on the fuel rail, there is a sensor that is on top of fuel rail or at end..
it has a quick connect with 3 pins/wires red/black/green
did you get any codes when you turn ignition on/off/on/off/on dont turn motor.. i didnt know about this trick til i started having problems and someone posted.
00 ram 5.9 cummins no start veedubmechanic Ram Pickup | Ram SRT10 1 09-02-2009 11:24 PM
2006 Saab 9-5 codes 1301 and 300 nero11 9-5 0 08-06-2009 08:45 PM
F-800 5.9 Cummins BigT73 F Series 1 01-30-2006 10:30 AM
5.9 cummins Crank Shaft Position Sensor P0336 dogwoodsales Ram Pickup | Ram SRT10 2 11-08-2004 12:40 PM
5.9 cummins deisel mods jc72 Ram Pickup | Ram SRT10 6 06-16-2004 09:23 PM
