Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-01-2009, 09:25 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
00 ram 5.9 cummins no start
I found 3 codes for the crank sensor, 3 codes for the injector pump, 2 codes for fuel pump, 1 code for no communication to ecm.
I erased the codes and the fuel pump codes came back.
I swapped the fuel pump relay with the high beam relay and the codes went away. It cranks and wont start. I looked at the values with my scan tool and there is no rpm displayed when cranking and the tach does not move. I was wondering if people know if crank sensors are a common issue with theese? Also is the crank sensor the one on the back of the timing chain cover?
(dealer said the truck needed a lift pump and injector pump, go figure. I have never seen an injector pump go bad unless its run with gasoline)
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-02-2009, 11:24 PM
hundahunta hundahunta is offline
Re: 00 ram 5.9 cummins no start
.......INJECTOR PUMP......I just change 2 in the past week....usually the lift pump, goes bad and the lack of fuel causes a premature failure of the injector pump....
