Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-20-2010, 03:22 PM
Wendy Cart Wendy Cart is offline
Key Ignition Solenoid '96 4Runner
I have been experiencing the key getting stuck in the ignition (ACC position) of my 1996 Toyota 4Runner. I've narrowed it down to the problem either being 1) a switch in the shifter assembly that tells the ignition the truck is in Park or 2) a component in the ignition (a solenoid) that allows the key to be released if the Park switch is pushed. I currently have the solenoid disconnected and the key comes out. Would that mean that the problem is with the solenoid or could the problem be the switch in the shifter assembly?
Old 12-22-2010, 06:26 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Key Ignition Solenoid '96 4Runner
The switch fails more than the solenoid.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
Can Not Remove Key - Key Release Solenoid MontanaDude Alero 2 09-30-2009 06:50 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
'96 4Runner rear wiper dead Leodogs Introductions 0 11-10-2005 09:41 AM
Cigarette lighter not working '96 4Runner karbine 4Runner/GX470 7 01-20-2005 02:17 AM
