Old 12-19-2010, 09:00 AM
MTG123 MTG123 is offline
Heater Blower Issue
Hi, recently I was driving down the road and my heater blower stopped. When I hit a bump in the road, it kicked back on. It did this periodically until finally it stopped blowing period. Any advice would be great!
Thanks,
Mark
Old 12-19-2010, 09:55 AM
riproaringca's Avatar
riproaringca riproaringca is offline
Re: Heater Blower Issue
I'd check:
a) fuses
a) the blower motor (found under the glove box area) to confirm a power connection hasn't been jarred/kicked loose and that the connection is tight
b) the blower motor's power connection for any signs of corrosion
Failing that, there are resistors associated with the blower motor to control fan speeds that may be faulty.
I had a ZX2 that had a blower motor connection right where the passenger could inadvertently bump it with his/her foot, thereby cutting power to the unit.
The actual power connection would also become corroded over time. A little sandpaper on the connector tang took care of that problem.
[email protected]
Peterborough, Ontario
1995 Escort LX 3DR - 1.9L, 4cyl. w/ OD
1997 Sable GS Wagon - 3.0L, 6cyl. w/OD
1997 Expedition XLT - 5.4L, 8cyl. 4x4 w/OD
1999 Escort ZX2 Coupe - 2.0L 4cyl. w/OD
1999 Taurus SHO - 3.4L 8cyl. w/OD
2002 F150 4x2 SuperCab XLT - 4.6L 8cyl w/OD
Bizarre Heater Blower and other Electrical Issues etaoinsh Caravan | Voyager 17 12-08-2009 09:17 AM
Flasher fuse and Heater Blower issue direland Caravan | Voyager 8 02-26-2008 10:15 AM
heater/blower issues....'93 Delta 88 LSS JesTTR Eighty Eight 7 08-25-2006 10:02 PM
Electrical Issue / VSS & Heater Blower ? GeneP S-10 0 03-24-2005 01:42 AM
'98 heater blower issues ronnyvous1 Durango 0 10-17-2004 11:18 AM
