Old 12-18-2010, 10:13 PM
lumina_98 lumina_98 is offline
vacuum and compression testing 3.1L
Is there a capped off service port somewhere on the intake manifold where I can attach a vacuum gauge? If not then something I can remove and install a T fitting I guess.
I also need to compression test this engine. Any tips on how to screw a guage into the back of this engine would be greatly appreciated. I had a terrible job changing the plugs even with the engine rotated so expect to spend hours getting the gauge in one hole. Maybe the engine will move forward more than I had it. Can I leave the engine rotated forward and run the starter to do the tests or will I need to reposition the engine and dogbones?
Old 12-19-2010, 08:19 AM
maxwedge maxwedge is offline
A990 racer
Re: vacuum and compression testing 3.1L
The should be a port on the engine if not use the power brake hose with a reducer to the gage. You can rock the engine and still crank it over, the rear are problematic no matter what with the gage hose making bends.
95 3.1 Air Conditioning nato38 Grand AM 4 06-30-2010 07:23 AM
Need Vacuum diagram for '95 3.1L (or other year) TexasGuy Lumina APV 5 08-26-2009 09:18 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
92' 3.1L - Battery draining but alternator and battery test good... ppjn348 Lumina 2 01-10-2009 08:29 AM
1996 3.1L Plenum (Upper Intake Manifold) vacuum hose ogre73 Lumina 2 03-05-2004 12:10 PM
