Old 12-16-2010, 06:35 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
08 trailblazer brakes sticking
my parents have a 08 trailblazer and the brakes stick. basically sometimes you stop and wait at a light or a stop sign, let off the brake and you can feel them stick for about a second and then release. they took it to the dealer, they said they felt it also but dont know what it is. we know its related to the brakes cause they take it there and they say they cleaned up the brakes and then it wont do it for a week or two then it will start doing it again. its still under warr. any ideas on what it might be?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 12-16-2010, 07:11 PM
maxwedge maxwedge is offline
A990 racer
Re: 08 trailblazer brakes sticking
All the brakes, ft rear? Not much info to really help out here.
Old 12-18-2010, 07:38 PM
dont know if its the front or back. just as only after a stop. it doest it like 1 time out of 50 stops so you never know when its gonna do it. i was talking to another mech and he said it might be computer related or something with the abs. how would i be able to find out if its the front or back?
Old 12-19-2010, 08:24 AM
A990 racer
Are you sure it is the brakes doing this? Could be a delay in throttle response or even a hesitation in the trans. I would have the brake system checked, could be a sticking caliper or the problematic rear parking brake shoes inside the rotors, they could do this also.
Old 12-19-2010, 09:20 AM
well she never uses the parking brake so it cant be that. as for the throttle or trans, it does it before you hit the throttle. you come to a light and sit there it turns green and u let off the brake and it acts like they are still on for a sec and then it releases and then all is fine.
Old 12-19-2010, 01:57 PM
A990 racer
Ok, check the brake fluid make sure it doesn't look contaminated like some put some p/s fluid in it by mistake. It will not mix with the brake fluid and has an oily feel on your fingers, brake fluid is almost more water like. If so this causes the by pass port in the m/c to be partially blocked by swelled piston seals, of course without a thorough onsite brake system check this is all 2cnd hand guess work.
Old 12-19-2010, 07:04 PM
its been doing it so i dont know about the fluid being able to be contaminated. but is there any way to test the master cylinder to see if maybe its just a bad factory one?
Old 12-20-2010, 07:45 AM
A990 racer
Never seen a m/c go bad in this manner without the seals swelling from wrong fluid. There is really no definitive test other than getting the brakes not to release then cracking the lines and releasing pressure to confirm the m/c is the culprit.
Old 12-20-2010, 02:55 PM
j cAT j cAT is offline
I would bring to another dealership and have them check it out ! keep all paper work ..
If you have the ability to jack up vehicle , do so and with vehicle running apply brakes and release then see if the brakes work correctly.
since this is a 2008 I would say a defective brake caliper / piston.. I had this on my 2000 silverado..piston would hang up when brake pads worn at 50 %.
removed these pistons found them to be bell shaped..
a defective caliper will show itself with greater pad wear/more dust on wheels than the other wheels !
if the other dealership is just as bad , best get this repaired at a competent auto repair shop where the work is guarranted.
keep all paper work ..then with the defective parts and your failed GM repair papers have them cover these costs.
report back how this all worked out ! could be a recall because of these issues here !
Old 12-20-2010, 03:17 PM
found this from a 2008 trailblazer owner !
4/28/2009 - RENTON, WA
I WAS STOPPED FOR A RED LIGHT ON A SLIGHT HILL. WHEN IT TURNED GREEN I TRIED TO MOVE AHEAD AND ALL 4 BRAKES HAD LOCKED UP AND I HAD NO FORWARD MOTION. I PUSHED HAD ON GAS PEDAL AND WAS ABLE TO CREEP AT ABOUT 1 MPH TO A DRIVEWAY. WHEN I ENTERED DRIVEWAY I HEARD A "CLINK" AND BRAKES RELEASED.THIS VEH HAS 5200 MILES AND IS A 2008 TRAILBLAZER SS AWD. THIS IS THE 1ST INSTANCE OF THIS TYPE.I TOOK IT TO MY SERVICING CHEVY DEALER AND THEY CHECKED IT OUT AND SAID THAT "MECHANICALLY " IT WAS FINE. THEY CONTACTED CHEVROLET TAC AND WERE TOLD THIS HAS NEVER EVER HAPPENED IN THE WHOLE DATA BASE FOR GM AND NO REPAIRS AUTHORIZED TILL IT CAN BE REPLICATED FOR THEM TO SEE. THERE WERE NO CODES STORED . THIS HAPPENED 0N 4-25-09. I WENT BACK TO DEALERSHIP ON 4-28-09 AND THE AGAIN CALLED TAC TO SEE IF THERE WAS ANYONE WHO HAD INFO ON THIS TYPE OF FAILURE OF THE BRAKES....BUT AGAIN NO LUCK. I FEEL STRONGLY THAT THIS IS A SAFETY ISSUE AND CHEVROLET SHOULD BE DOING MORE THAN LIP SERVICE....
Old 12-20-2010, 03:39 PM
some found the master cylinder is incorrect for your vehicle. this causes intermittent brake lock up , all wheels..
they used a shim to change the master cylinder length , this solved the problem..
Old 12-20-2010, 07:03 PM
A990 racer
So the rod from the booster to the m/c was in effect too long, not allowing the by pass port to open, from day one of manufacture?
Old 12-20-2010, 07:14 PM
the fleet mechanics that have these vehicles in there owners business stated that this shimming is the fix...I believe too, that the rod must be too long.. thin washer was used to fix the problem ..
GM so far has no clue on what is the fix... to intermittent ..
pedal does not fully return, brakes stay applied to full or some lesser amount.
you see this before ?
Old 12-20-2010, 07:47 PM
so i can add a washer to it and it should take care of it? i know the dealer told them that since it hasnt cause a safety issue that gm isnt going to recall it or do anything about it.
Old 12-20-2010, 07:54 PM
A990 racer
Question Re: 08 trailblazer brakes sticking
Yes but on classic car disc brake conversions I do in my shop, I have not heard of the issue on a modern car, seems this would have been corrected from day one if the truck was built that way, there are no TSB's related to this.
2205 Trailblazer Brake Controler Wiring siredward6 TrailBlazer | Trailblazer EXT 1 07-06-2008 04:55 PM
03 trailblazer brake lights inop. debkev TrailBlazer | Trailblazer EXT 4 08-22-2006 11:08 PM
96 blazer rear brakes sticking mkennedy Blazer 2 04-21-2004 01:27 AM
F-350 Brakes sticking/dragging Racer561 F Series 2 04-01-2004 02:54 PM
brakes sticking... 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 8 11-12-2002 09:56 AM
