Old 11-10-2002, 11:53 PM
91civicDXdude's Avatar
brakes sticking...
when im driving i get brake squeal. how do i stop the brakes from sticking?
Old 11-11-2002, 11:11 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
are you sure your pads arent low and its the little metal tab telling you to get new ones?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 11-11-2002, 02:09 PM
kris's Avatar
kris kris is offline
Off playing with fire.
ditto
Old 11-11-2002, 02:40 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If your brakes are sticking they won't squeel, they will smoke since the rotor is burning up the pads. Sounds like you got what the other guys said.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 11-11-2002, 08:34 PM
no i just replaced the pads/rotors about 4 months ago. i had a similar thread as to why my brake pedal goes to the floor and the brakes dont stop. also, it seems like they fade really bad. this made me think that the brakes were sticking and heating up the pads the whole time making the braking bad. then i listened as i was driving along and the brakes make a squealing noise like they are in need of pads, but how? i've bled the system, rechecked the pads, it is all good.
Old 11-11-2002, 09:13 PM
Pedal going to the floor with no braking is either air in the lines, low fluid, or your brake booster is dead.
Old 11-12-2002, 01:08 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
ditto... check your fluid level, try to rebleed and if it it still goes to the floor your master cylinder is prolly going buh byes...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 11-12-2002, 01:49 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
it is your brake booster. my friend had the same problem that u just discribed
My Name is Roberto AKA. Berto
Old 11-12-2002, 09:56 AM
normally if it is the brake booster it would be harder to push not easier. it isnt low fluid or bleeding problems. It is probably the master cylinder.
