Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 12-16-2010, 03:38 PM
kurkovn kurkovn is offline
1996 Jetta. Hard Check engine light
Hello,
I have a 96 jetta gls, 2.0 Litter. I really need help to get the check engine to go off. It is super complicated. As of right now I have six codes. They are:
P0327
Knock sensor 1 circuit low imput bank 1 or 1 sensor
P0440
Evap emission control system malfunction
P0133
O2 sensor CKT slow response (bank 1 sensor one)
P0171
System too lean
P1613
Manufacturer control auxiliary inputs auxiliary outputs
P0125
clad loop fuel ctrl insufficient coolant temp
When the codes are erased, the light turns off. Then when you start driving it and you give it like gas so that the rpm go over 3 thousand, the car jerks and the check engine comes on. This code that first comes on is the knock sensor which I replaced already. Some of the other things I have replaced are
1. MAF sensor (from a car without a check engine)
2. Oxygen sensor
3. Spark plugs
4. Distributer rotor
5. Distributor cap
6. Spark plug wiring
7. Cleaned the fuel injectors at a fuel injector shop
8. The fuel filter
9. Fuel pump
10. All the belts
11. Both oil pressure sensors
12. Ignition switch
My biggest question is why the knock sensor still comes up? I also have a water pump installed that was installed before I got the car. It is installed a little bad and causes the belt not to be 100% lined up with the ac and alternator. Also other symptoms that I have with the car is that it starts up pretty bad sometime, the engine turns over but does not catch the spark until you press the gas pedal all the way. And last but not least is when I am driving almost all the time, you feel a little jerking of the car. Like most people will not notice it at all, but I feel it. So that is basically it. If someone knows how to help please, I really just want to get rid of the check engine and maybe sell it.
Old 12-16-2010, 10:46 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 1996 Jetta. Hard Check engine light
you probably have a couple problems. Inspect the round engine harness connector by the distributor, it has about 30 wires in it. You twist counter clockwise to unplug it. THe wires sometimes get corroded and burnt and cause lots of engine codes
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
