Old 12-15-2010, 12:17 PM
thetandycollector thetandycollector is offline
Send a message via MSN to thetandycollector
93 GA: Runs, then dies and won't start for 2hrs.
Hello all, have a perplexing issue with a 93 GA in the shop. Been here for a while, we've been going through alot of basic repairs on this car, following normal diagnostics procedures. However, we haven't managed to fix the problem.
This car will run for an indefinite amount of time, runs just fine. But then, suddenly, it will die like someone just turned the key off. No miss, no chug, just dies. Then it won't start for an hour to two hours. You can walk right up to it then, put the key in the ignition, and it starts up just like it should, no problem. Any help? We've replaced vacuum lines, TPOS, CKPOS, CMPOS, others.... Was thinking maybe a coil pack controller module????? I've had those get hot before and do wierd things.
Oh yeah, it's a DOHC motor car... 2.3L Automatic. Thanks for any help I can get!
Bill - Eagle Auto
Old 12-15-2010, 02:03 PM
jdl jdl is offline
Re: 93 GA: Runs, then dies and won't start for 2hrs.
When the problem occurs, did you visually check for spark at the plugs? Also, use a gage and check fuel pressure. Any applicable mil codes? You have to test when problem is ongoing.
Runs good for 20 minutes, then dies and won't start until the next day whoaskew C/K 57 10-26-2016 11:00 AM
Runs good for 20 minutes, then dies and won't start until the next day whoaskew C/K 1 03-31-2010 09:18 AM
1990 plymouth voyager runs till hot then dies and wont start for 20 mins! thunderbirdsc Caravan | Voyager 1 02-12-2010 07:50 AM
truck dies and won't start for hours shift9624 Sierra 2 02-23-2007 02:12 PM
Transport dies and won't start for 15 mins westb010 Trans Sport 5 04-20-2005 06:54 AM
