Old 12-13-2010, 05:51 PM
82Stang 82Stang is offline
1998 Windstar power steering line routing...
1998 Ford Windstar 3.8L
I replaced a section of line on the return line hose, but had the pressure line off too. Ever since the low pressure line keeps blowing off the hose replacement, even when double clamped. I'm thinking I may have switched the lines by mistake, but not certain. Can anyone tell me where exactly each hose goes from pump or front to rack and identify the ports on the rack. Looking at the rack from the front of the car, there are two ports one above the other. Which is high, which is low? The way I have it, lower is low side and runs up around pump to front lower part of vehicle. And the top port I have as the high port going up directly to the pump and bolted on front. Is this correct?
Thanks for replying.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 12-14-2010, 07:55 PM
wiswind wiswind is offline
Re: 1998 Windstar power steering line routing...
I tried looking this up last night......in my pictures, on alldatadiy, and the pictures of parts on the rockauto website.
I do not have any pictures that show this on my '96 windstar.....and I no longer have it to go out and look at (sold it this past spring).
The drawings that I look at seem to look like it is the top line, but they are not good drawings......to say the least.
The instructions on AlldataDIY mention dressing the high pressure line in from the top and the low pressure line in from the bottom, but that does not say much.
Hopefully, someone can provide more solid information.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-15-2010, 08:06 AM
Thanks for looking Wis. Even having a vehicle in front of you, it's still hard to see. You'd have to get under it. I just can't seem to find any diagrams showing exactly which line goes where. Strange.
Rodney Dangerfield
Old 12-15-2010, 04:55 PM
Called local Ford dealer. they didn't have a clearcut diagram either. Guy thought the lower port on the rack was the high pressure line and routes up to front to cooler down below. I don't know if that sounds right. Something seems amiss there, not sure.
Rodney Dangerfield
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
How To R&R 1998 Grand Caravan Power Steering Pump CarBob Caravan | Voyager 0 04-04-2010 10:59 AM
power steering problem in the rain eu0688 Impala | Impala SS 2 12-13-2009 11:23 PM
1995 Windstar power steering hose/line Greg W Windstar 2 11-24-2007 11:45 PM
1998 Windstar Power Window Jeff157 Windstar 4 12-24-2005 03:03 AM
