Old 11-20-2005, 09:24 AM
Jeff157 Jeff157 is offline
1998 Windstar Power Window
Hi..I am a new member and I hope you can help...About a month ago the passenger power window switch would only work sometimes, but I was able to use the driver's control to operate the passenger windwo with no problem. Now, neither control will work the passenger window. I jumped the motor from the battery and the window went up. Which switch should I replace or is there a different problem? Thank you very much...Jeff
Old 11-24-2005, 03:49 PM
Is there anyone that can help me with this power window problem? Thanks..Jeff
Old 11-24-2005, 03:57 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 1998 Windstar Power Window
Jeff
I would check to see if there is power to the switch. If there isn't power to the switch get a good wiring diagram and see where the power comes from.
I had both motors go bad within a week of each other. I know you said that you were able to jump the motors and they worked. Just another angle to look at.
Post back about power to the switch.
Regards
Dan
Old 12-12-2005, 01:53 PM
flashsteveo flashsteveo is offline
Re: Re: 1998 Windstar Power Window
Originally Posted by LeSabre97mint
Jeff
Regards
Dan
Im tryingtofind the relay for the motars and fan controlls for the front and back heaters steve
Old 12-24-2005, 03:03 AM
rrclyoung's Avatar
rrclyoung rrclyoung is offline
replace the switch on the passenger side...this switch has gone bad. The switch on the drivers side goes through this switch to make the window open/close. That explains why you could operate it with the drivers side before the switch went totally out.
