Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-13-2010, 12:30 AM
Rickyboy1958 Rickyboy1958 is offline
Cylinder #5 Misfire
I have a 1999 5.7L Suburban that has an engine problem. First off, I'm losing coolant and it is not leaking externally. Second it has a misfire on cylinder #5. The spark plug shows good spark, so the cylinder is getting electricity. Compression is 105 psi and #1 cylinder compression is 190psi. Is it a blown head gasket or something else?
Old 12-14-2010, 05:35 PM
j cAT j cAT is offline
Re: Cylinder #5 Misfire
remove valve cover could be cracked head..or a head gasket.
compression check says its loosing #5 cylinder psi..
what coolant do you use ?
Multiple cylinder misfire codes Pokee Windstar 6 05-04-2010 09:10 PM
Cylinder #6 misfire Pipeplug Sable 3 02-07-2010 09:34 AM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 06:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-06-2009 11:31 PM
