Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 02-06-2010, 03:51 PM
Pipeplug Pipeplug is offline
Cylinder #6 misfire
I've just been told after two trips to the mechanic cyl#6 is misfiring. It only gives a soft code (check engine light flashes for 30 - 40 seconds then goes out) so it was hard to detect. Problem only occurs when either sitting at idle with electronic climate control ON especially when the A/C compressor kicks on or going up a hill, accelerating on to the expressway for example. It's the DOHC Duratech engine in a 2003 LS Premium.
He has suggested starting with changing the spark plugs first. Next the wires and then finally the coil pack. How does a coil pack differ from the old style coil and would it be possible for only one cylinder to be affected by a defective pack?
Finally, any other ideas?
Thanks for your time.
Old 02-06-2010, 04:18 PM
danielsatur danielsatur is offline
Re: Cylinder #6 misfire
Yes! Roll the coil pack.
If not the Spark plug, wire, or coil, do the injector next.
Old 02-06-2010, 06:44 PM
Thanks for the reply. Tried plugs today. No change so wires tomorrow.
Old 02-07-2010, 09:34 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
I have the same car. Mine will misfire if the plug wires get wet. The last time I power washed the engine some water got down in the plug cavity. Dried things out and everything is fine. I would suspect the wires. The coil pack is probably fine, never heard of one going bad on one cylinder only. I suppose it is possible, but unlikely.
Since you have the exact same car. I was just wondering if you have had any problems with that electronic climate control unit not working or the dash cluster lights going out ?
Good luck
Mike aka JYD
Tags
coil , misfires , pack
