Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-12-2010, 07:56 PM
03GMCSonoma 03GMCSonoma is offline
Headlight problem
95 Ranger XL pickup truck headlights work only on low beam. When I select highbeam I only have daytime running lights and also no highbeam indicator. Someone told me it was the daytime running lamp module. Is there a way to verify this diagnosis? I checked the headlamp bulbs and they are ok. Checked the power coming out of the dimmer/multifunction switch and it is ok.
Old 12-23-2010, 07:34 PM
lectraplayer lectraplayer is offline
Re: Headlight problem
When you "brighten" your lights, does your instrument panel go dark or otherwise change brightness?
problem removing old headlight erratic Galant 0 10-17-2010 01:33 PM
99 Problems with headlights Superman08 Galant 1 08-16-2010 08:09 AM
96 G.A. headlights problems tinman55 Grand AM 3 11-10-2009 05:36 PM
2002 Eclipse Headlight Problem Destroyus Eclipse 2000+ 0 07-03-2009 04:25 PM
headlight problem automatic headlights 93shoblkmtx Taurus | Taurus Wagon 4 11-04-2004 02:54 AM
