Old 12-12-2010, 06:54 PM
riproaringca's Avatar
riproaringca riproaringca is offline
99 SHO: 1) Cam Sprocket Welding, 2) Check Engine Light (CEL) - Code P0172
Hey all,
Just another post that may help steer you in the right direction if you have a similar issue with your '99 SHO:
1) Took the car to Northeast SHO in Spencer, MA back in November to have the cam sprockets professionally welded. Kirk Doucette is the man to see in that area! Friendly, knowledgeable and efficient. No more worries about a sprocket spinning off of a shaft!
If you do get your welding done there, I suggest staying at the Spencer Country Inn -- just a mile down the road from the shop.
2) One evening just last week the Check Engine Light (CEL) came on in the midst of a deep freeze here. With an upcoming road trip and unfavourable working conditions outside I took the SHO into the dealer the next morning. They were able to get a P0172 code indicating that Bank #1 was running rich. Further investigation showed that the Mass Air Flow (MAF) Sensor was dirty and the shop guys were able to clean it up a bit. No need for a new MAF at this point, but maybe in the future. Codes were cleared and so far the CEL is staying dark.
When the CEL came on initially the car was running fine. The exhaust did smell a little different than usual, but I thought that might have been a temperature thing. No rough idle, no hesitation - but that might have happened if I hadn't taken it in right away.
[email protected]
Peterborough, Ontario
1995 Escort LX 3DR - 1.9L, 4cyl. w/ OD
1997 Sable GS Wagon - 3.0L, 6cyl. w/OD
1997 Expedition XLT - 5.4L, 8cyl. 4x4 w/OD
1999 Escort ZX2 Coupe - 2.0L 4cyl. w/OD
1999 Taurus SHO - 3.4L 8cyl. w/OD
2002 F150 4x2 SuperCab XLT - 4.6L 8cyl w/OD
Last edited by riproaringca; 12-12-2010 at 07:16 PM. Reason: Wasn't finished with initial content.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
