Old 05-23-2003, 05:44 AM
dvdfreak dvdfreak is offline
need help on tamiya spray can
I have just tried it,
heat up with warm water,
but it turn out to be too messive for me to handle.
I just can't spray a light coat at all,
how do you guys do it?
hold the button down and move very fast or just press the button one time after another
I have browse the faq, but there is little info on this
Old 05-23-2003, 05:52 AM
hrmodeler's Avatar
hrmodeler hrmodeler is offline
Send a message via ICQ to hrmodeler Send a message via MSN to hrmodeler
For light coat you go faster, for hard slower.
You must start before model and end after it, don't stop while you are on model.
Zeljko Segin
http://www.hrmodeler.com - Fast wheels - my pages
My current project - .....
Old 05-23-2003, 06:02 AM
should I hold the button all the way down or just not push to hard to reduce the spray
Old 05-23-2003, 06:03 AM
and how can I spry some unreached curved part without mess up other area?
thanks
Old 05-23-2003, 06:09 AM
practis makes progress
It is better now after tried sevral times
but should I keep a longer distance when doing a light coat?
what is the ideal distance for each kind of coat?
hrmodeler's Avatar
Push it enough to have nice flow. If you push it lihgtly paint will spit on model.
Put couple light coats and curved areas will be covered too.
Zeljko Segin
Old 05-23-2003, 06:47 AM
thanks a lot for your help
Old 05-23-2003, 04:22 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
This is what I usually do.
Old 05-23-2003, 07:16 PM
Deejay27's Avatar
Deejay27 Deejay27 is offline
I've learned to paint the "hard to reach spots" first and then paint the large areas. I found this method reduces the overspray on the large areas and results in a glossier finish.
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 05-23-2003, 11:24 PM
BWheel BWheel is offline
Hey, DVDFreak,
Sounds like you're heating the can too much, which will increase the pressure so that it comes surging out of the can. If you can hear the can 'fizzing' as you put it into the water, you've got the water way too hot. Should be warm, not really hot, just to stabilize the temperature a bit.
Definitely do NOT put the can into boiling water. The temperature could increase the pressure to dangerous levels. You don't want to end up with a weak can blowing to bits in your hand.
As you spray, you'll notice the can cooling a lot. This is due to the expansion of gases - keeping the temperature stable is the trick.
Good luck with it all...
B
Completed:
Tamiya Subaru WRC Monte-Carlo
Revell Eddie Hill Top-Fuel Dragster
Revell T900 'Australia'
Tamiya Enzo Ferrari
Tamiya Honda NSR
Current Project:
Revell Fire Truck
Old 05-24-2003, 06:39 AM
Originally posted by BWheel
Hey, DVDFreak,
B
I just put the can in warm water that I can hold my hand in it as Pman's instruction.
and I did not hear it make any sound in the water.
thank you for your reminding
Old 05-24-2003, 07:02 AM
primera man's Avatar
"P-Man"
*Hold the button right down all the time.
*Spray your light coats around 10-12 inchs from the model. Spraying at a quick stroke.
*For the finish coats you should be slower and closer to the body.
*You must start spraying before model and end after you pass it, don't stop while you are half way along the body.
*The water should only be warm enough so you can put your hands under the hot water.
View All My Models Here.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
