Old 12-11-2010, 01:37 PM
someday31 someday31 is offline
03 Silverado gauges
Started my 03 silverado 1500 this morning and all gauges didnt move. I started the truck multiples times during the day today. My milegae/blinkers, etc all light up. My question is, when these go would ALL gauges flatline? Im at 120,000 miles and this is already a remanufactured cluster at 60,000miiles. Should I just assume all stepper motors are shot???
Old 12-11-2010, 03:12 PM
danielsatur danielsatur is offline
Re: 03 Silverado gauges
Check for fuse's and bad connections.
It could be simple as resetting a connector.
Old 12-12-2010, 08:08 PM
I started the truck this morning and the gauges were all working....but the truck sounded extremely weak when cranking, like it wasnt going to start. So could low voltage/amps cause gauges not to work but everything else to seem ok?
Old 12-12-2010, 08:22 PM
j cAT j cAT is offline
check for loose fuses...they should set very tightly in the holders..
all grounds on engine frame need removal and cleaning...also the battery leads/connections for corrosion and security..
have the battery load tested should be above 400 amps..green zone ..
using a voltmeter you should get 14.25 volts when engine hot at air temp of 40 deg f.........
4R55E Front End Play Check Gauge Bar T93T-77003-AH mrstubb Explorer | Explorer Sport Trac 0 06-13-2010 02:59 AM
1997 silverado slowly lost power mcgyver65 Silverado 8 05-26-2009 08:53 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
WTB A/F Gauge and Boost Gauge w/ vac ned032002 Classifieds 1 10-28-2007 11:05 PM
2005 Silverado front end converison on 2000 Silverado Oscar_grouch Silverado 3 03-18-2007 03:37 PM
