Old 12-10-2010, 01:59 AM
mo_86_05 mo_86_05 is offline
02 trailblazer rear heat problem..blowing cold air
I have a trailblazer ext..i think..its got the third row seating...anyhow, the air works fine in the rear of the vehicle...heat is where im having a problem. I have both the driver and passenger temp set to 90 degrees and then i turn the knob i have below my radio to turn the heat on in the rear and nothing but cold air comes out. In the rear, it has a temp control setting with the radio for those in the rear..everytime i try to change the temp on that cluster, it flashes like three of four times but nothing changes. What could be the problem? Just give me somewhere to start..is the rear cluster bad?
Old 12-10-2010, 09:12 AM
maxwedge maxwedge is offline
A990 racer
Re: 02 trailblazer rear heat problem..blowing cold air
Could be, if it flashes it is seeing a fault. You will need an OE shop manual to track this down.
Old 12-12-2010, 10:38 PM
roadie sais that its more than likely an actuator messed up..he suggested i take off the rear panel and watch it..which panel do i take off...and what do i need to watch for?
Old 12-15-2010, 07:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Who is roadie sais?
But.
Like Maxwedge says.
You need some good repair info.
With auto matic Ac/heater controls a Body/HAVC capable scanner check will point you to the problem.
If you get any code no post back codes.
Got any repair info?
If not Good Old factory OEM manual or A good All Data online DIY repair info sub will help you out.
A lot of public libarys also have car repair info.
MT
2001 rear air only blows cold air nosagroy Suburban 1 06-10-2010 09:21 AM
Heater starts blowing cold air on passenger side? BDeHaven13 TrailBlazer | Trailblazer EXT 3 03-10-2010 11:14 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 09:49 AM
2003 yukon rear heater unit blows cold air ross96 Yukon 2 11-19-2007 01:45 PM
Heat in Rear working, Heat up front still blows cold air?? pspierce Montana/Montana SV6 1 03-04-2006 11:54 PM
