Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-09-2010, 12:12 PM
rubs rubs is offline
Noise after repair
On 2001 i30 with 123k miles I just had replaced following parts from new mechanic (my mistake):
disc brakes pads and rotors
Both side drive axles
outer tie rod
left control arm with ball joint
Now when I start car in cold morning or when it is about to stop near red light etc it makes lot of squealing from brakes otherwise brakes are fine so not sure if mechanic forget to put some lubricant etc or this is just feature of brakes nowadays?
Also when I turn left or right at very slow speed, I hear click click noise so not sure it can be symptom or faulty drive axle or some nut is not tight etc?
Any feedback would be appreciated since I would like to get some feedback before going back since he may try to sell something else.
Thanks
--rubs
Old 12-09-2010, 01:42 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Noise after repair
outer tie rod
Thanks
--rubs
The brake related noise should go out by itself soon ... or if not, maybe the caliper anti squel bits are now missing? Nuisance problem - but with all new parts, they should be silent. Alas, very few use lube - check out my brake-page, link below
I hope the fluid was changed also ... should be swapped every 2-3 yrs.
Axle/supports:
Maybe smtg is a little loose, strut bearings now noisy? If that can be heard every time as described, the reason should be inspected. The shop should check these free ... you just keep the wallet closed.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Repairs after roll over? PCruiseW SC/SL/SW 8 02-25-2009 07:57 AM
99 taurus power steering hard after repair robertes Taurus | Taurus Wagon 0 09-28-2004 04:01 PM
Necessary to clear / reset ABS after repairs? Spinman Aurora 3 06-25-2004 04:46 PM
Cavalier won't start after repair ALinVA Cavalier 1 04-01-2004 09:26 PM
Car is still shaky after repair Gambit_Force Escort 3 08-26-2002 03:51 PM
