Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-09-2010, 08:40 AM
Larryuidiot Larryuidiot is offline
Head Gasket
My son has a 2001 Integra Ls.He overheated it the other day and said it got into the red on the guage.He let it cool down and drove it home.Put some antifreeze in it and the next morning drove it to school with no problems.
The following day was real cold about 20.It wouldnt start ,I pulled a compression check and they were about 125 in each cyl.I changed out the plugs and did get it running.
He has been driving it but said it will overheat on him if he gets into it.He has a turbo on this.Its only overheating if he gets into it but it's 10 degrees out now.Said he thinks it will overheat always when it warms up.
WE changed the oil, antifreeze is good.I think the head gasket is blown but dont know why it doesnt overheat all the time.There is no water in the oil .
Hate to break it down and put a head gasket on if that isnt the problem.
Old 12-09-2010, 06:26 PM
danielsatur danielsatur is offline
Re: Head Gasket
Have the tubro + catalytic converters checked.
Old 12-09-2010, 06:52 PM
Scrapper Scrapper is offline
AF Premium User
Re: Head Gasket
i agree on being the cat and yes probaly he blown a head gasket and maybe even a crack in the head it only take's one time to crack. good luck....
Old 01-11-2011, 12:35 PM
carlos2010 carlos2010 is offline
Re: Head Gasket
hi & happy new year
i have a 1.4 16v renault clio and it started with dark thick smoke coming out of the exhaust and lots of it (and smelly) i was advised to changed te plugs so i did and it did not help now i find myself changing the plugs every other day and the car is juddering and lacks power i find it hard to reach 50mph ... please can you help me
thanks
Old 01-12-2011, 11:16 AM
AF Premium User
Re: Head Gasket
check your oil and see if it has a milky look to it? if it has could be head gasket and anitfrezze if fowling out the plugs take one out see if it's wet with gas and anti frerezze. if theres oil on them souds like you need new rings or maybe valve seals. that smell you smell i'm leaning torward head gasket and maybe head. i doubt egr valve.
Old 02-05-2011, 09:00 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Head Gasket
op, could be the thermostat. worst case could be water pump
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
01 grand am 3400 head gasket? LoMbArD Grand AM 33 10-19-2009 12:29 PM
Head Gasket Leak el ratfink General Discussion 4 08-14-2009 06:04 AM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
'92 SC - head gasket - replace both head gaskets? kaje71 Thunderbird 2 09-05-2008 05:10 PM
