OBD1 Code Retrieval
I have a 95 APV with a solid SES light. To get the codes, according to the Haynes Manual, on the "Assembly Line Data Link" (diagnostic connector) I need to use a jumper wire (or paper clip) and ground out pin A (ground) and pin B (diagnostic terminal) on the diagnostic connector. The connector has pins that look as follows:
F E D C B A G H _ _ _ M A is the ground, and B should be the diagnostic terminal, but there is no wire going to B. What I have is a black wire with a tracer going to A, a tan wire going to M, and a purple wire going 2 holes to the left of M (the manual has no letters for these 3 pins). Near as I can tell, the tan wire (M) is the serial data pin. So which two do I ground out to get the trouble codes? Thanks!!!! Roland |
Re: OBD1 Code Retrieval
The OBD I scanner is cheaper, but consider the one thats does both OBD I, and OBD II systems.
A local Auto parts can pull code for free, it's too hard to read morse code! |
I have the codes in my Haynes Manual, but I can't get the codes until I know which pin to ground with the ground (A). Then I can count the flashes and find the codes. Once again, thanks!! Appreciate all of the help I can get. |
If getting no codes -
1) Check fuse for the ECU. 2) Disconnect the ECU, clean connections, and reseat connector. Tools: Brass like tooth brush, and CRC electrical cleaner. |
I have only 3 wires coming into the back of my connector. There is the black wire with a tracer in "A" (top right on the connector), and this is the ground. There is a tan wire in "M" (bottom - just below A). The only other wire that I have is a purple wire that is 2 spaces to the left of "M" on the bottom row (no letter given in the manual). Question, do I ground out "A" with "M" to get the codes, or do I ground out "A" with the purple wire? Or, (and I guess this is a possibility), am I for some reason missing the appropriate wire(s)? I read that if I do it wrong, I can damage the PCM. Ugh!!!! |
Beginning in 1994, GM began the migration to the ultimate goal of all vehicles being OBD-II compliant, and these vans were in the 20% or so that were sent over prior to 1996. Actually, it is a hydrid, mostly OBD_II compliant, yet packed in an OBD-I form. You have oberserved this by the changes in the ALDL connector.
The short story to this is that you cannot use the paper clip trick on 94 and 95 vans, a scan tool has to be used, just as you do for 96 and up OBD-II. If you buy a scan tool, make sure it will in fact read that van, a lot of the more inexpensive ones may only read true OBD-I, and not the vehicles that were caught half way between the 2 systems Jeff Last edited by Jeffrv; 12-09-2010 at 07:52 PM. Reason: editorial |
Merry Christmas (if you keep it). Roland |
I am instructed to ground terminal (or pin) "B" with pin "A" (can use a paper clip) and then turn the ignition on - then count the flashes of the SES light. My problem is that there is no wire going to "B" at all! All I have in my diagnostic connector are: "A" (a black wire with a tracer), "M" (a tan wire) and 2 spaces to the left of "M" there is a purple wire (no letter given). Thus my dilemma! There are only 3 wires going into my diagnostic connector (yes, it is a 95 Lumina APV). Thanks again, Roland
And Jeffrv told you. Quote from the bat link. NOTE: Some 94 & 95 models do not have the B terminal. In which case a scanner is required. NOTE: Some 94 & 95 models that DO have the A & B terminals still require a scanner. All vehicles after 96 are OBDII,and require a scanner to access them. Also a special scanner and adapter is required for the 94-95. Very few auto parts places can read the 94-94 codes if no B pin/wire and even some with the A and B pin. You will need the special scanner and adapter and engine cartriage for that year.
