Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-08-2010, 02:52 PM
x3mtm's Avatar
x3mtm x3mtm is offline
Send a message via AIM to x3mtm
Exclamation water pump or radiator?
hi i have a 99 dodge durango and its been having problems with the water pump. its leaking from the shaft, so is there any way to fix that without having to buy another pump? now, today as i was going on the high way, the engine temp went up to max for like 2 min and it came back down. i though the water pump finally broke, but when i got home, the pump was fine and it still had coolant in it. the radiator cap was cold and when i opened it, it sounded like there was coolant going thru the engine. i touched the upper hose, it was hot, but the lower one was cold. i dont know if its the pump not pushing the coolant or the radiator has a restriction not letting coolant pass thru it. i put some coolant in the radiator...again...the cap didnt get hot....but the engine went into overheating again for 2 min and then the temp came back down. any ideas?
Old 12-08-2010, 06:34 PM
danielsatur danielsatur is offline
Re: water pump or radiator?
A shortage of coolant will cause the engine to over heat.
When you loose heat from the heater, the coolant is no longer going to keep your engine cool, it's going to over heat and damage your engine.
1) Replace bad water pump, thermostat, and coolant ASAP..
Old 12-08-2010, 08:28 PM
urclueless urclueless is offline
Banned
hi i have a 99 dodge durango and its been having problems with the water pump. its leaking from the shaft, so is there any way to fix that without having to buy another pump? 4-5 cans of stop leak
air pocket caused by slightly low coolant or stuck thermostat or water pump impeller
lower hose is suppose to be cooler than upper, cold radiator cap indicates NO circulation, upper hose can be hot just from natural convection
fix what's wrong... oops, I forgot you want to fix the water pump without replacing it... just keep driving it, eventually the problem will go away
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 08:12 PM
5.2, Very hot in cab, radiator cold. mrspooks Ram Pickup | Ram SRT10 0 08-15-2009 09:55 AM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 04:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 02:17 PM
Lower radiator hose cool/Water pump squeal ktl4974 Problem Diagnosis 7 05-04-2009 09:44 PM
